How to change parking (citylight) bulb (W211-06)?
It might be easy for many of you, but I don't know where to start of changing the bulb for parking (city) light for my E350 (W211_06). I would appreciate if someone could illustrate the process of doing it. thanks in advance. James
It's pretty basic. Start on the drivers side first as there is more room. Look at where the city light is inside the headlight (from the front of the car) and then fish your hand down behind the headlight. You will feel two electrical connectors. The city light is the lower of the two. You simply rotate counterclockwise (if looking from the rear) or clockwise if looking from the front and then pull the long plastic housing out of the headlight. The city light will be at the end of this housing. If you look inside the headlight when you are turning the city light to get it out you will see the bulb start moving and you know you are on the right track.
Hope that helps.
Hope that helps.
