E-Class (W211) 2003-2009
Bi-Xenon
Old May 7, 2009 | 01:11 PM
ehdee21's Avatar
m35sport, e350w4
Bi-Xenon
Does anyone have a picture of 2 E's next to each other, 1 with Bi-Xenons and 1 w/o?
thanks
Old May 7, 2009 | 01:37 PM
MBZ16V's Avatar
1987 190E 2.3-16V
thanks
The only difference is the headlight washer, but the light assemblies themselves cannot be distinguished from each other until they are lit.
Old May 7, 2009 | 01:50 PM
ehdee21's Avatar
m35sport, e350w4
sorry, i shouldve specifiied "with the lights turned on"
thanks
Old May 7, 2009 | 01:53 PM
Txhurdle's Avatar
2012 ML350BTC
On the main head lamp, yes. But because of the 'Bi' part(with the high-beams also being Xenon) there is a difference there. The Blue E has regular headlamps, the White E Bi-Xenon's. You'll notice the Bi-Xenon's have a clear strangely tipped cylinder where the regular headlamps have a small Blue-ish bulb in this same spot.
These are both 2009.
Attached Thumbnails Bi-Xenon-p1vp2.jpg   Bi-Xenon-p1.jpg   Bi-Xenon-p2.jpg   Bi-Xenon-2p1.jpg   Bi-Xenon-2p2.jpg
Old May 7, 2009 | 02:01 PM
ehdee21's Avatar
m35sport, e350w4
any chance you has similiar pics but with the lights on?
thanks again
Old May 7, 2009 | 02:05 PM
Txhurdle's Avatar
2012 ML350BTC
As requested...
Old May 7, 2009 | 02:59 PM
Barry45RPM's Avatar
2015 ML 350
Just in case you are car shopping... The Bi Xenons in this car are the best headlights you will ever drive with. A truely amazing road illuminating system.
Old May 7, 2009 | 03:20 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
The 07+ come with headlight washers and no bixenons too.
Old May 14, 2009 | 04:15 PM
marcus7's Avatar
E63
Hello Im new so excuse my ignorance. I just purchased but havent pick up as of yet a 09' E63 without Bi-Xenons. What buld comes in the car and what manufacturer would you recommend as a replacement without having to go to a aftermarket Hid set up?
Old May 14, 2009 | 04:17 PM
marcus7's Avatar
E63
Excuse me....headlight bulb(typo)
Old May 14, 2009 | 04:24 PM
marcus7's Avatar
E63
The car is equiped with the Pano roof....any pros or cons?
Old May 14, 2009 | 08:49 PM
pinebaron's Avatar
07 E320 Bluetec
I love the Pano roof. I have had zero issues with it.
Old May 14, 2009 | 11:33 PM
CrimeDoesPay's Avatar
2004 e320
the clear strangely tipped cylinder is an led bulb thats all so that it matches the hid of the main head light
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old May 15, 2009 | 02:39 AM
gaazmon's Avatar
Pros: love the exterior and from interior. Wider opening IMO.
Cons: gets a little noisy after a while. Need to have it greased or something, but it's not that bad.
About the bulbs, I believe the head light is H7 (check osram sylvania's web site). So if you want HIDs, you either get a H7 kit or replace the headlamps with the OEM bixenon ones that turn (way more expensive than the 1st option). You can't just put a different bulb in, it will run hotter and burn the wiring, happened to a friend of mine.
Old May 15, 2009 | 06:31 PM
virgilwoods's Avatar
2006 E350
Is it possible to have Xenons in the big outside light, but not the inside little one?
