E-Class (W211) 2003-2009
can anyone help with ampg on 06 e350 4 matic
Old May 19, 2009 | 01:30 AM
D099y's Avatar
06 E350 4matic
hi, i'm driving a 06 E350 4 matic, in the beginning, i had the "s" option on, then i read it in the forums that with the "C" i can get more and it's better for driving, so that's what i did, but i don't really see a different in it.
right now, driving with "C" option, i get about 14-15.5 mpg on local and about 19-20.4 mpg on highway.. is that good or bad?
Old May 19, 2009 | 12:40 PM
Barry45RPM's Avatar
2015 ML 350
I drove from DC to NY Sunday & got 27.6 MPG @75 MPH
Driving in C eliminates the use of 1st gear & also lets the transmission make shifts at a little lower engine RPM. Basically is yields a tiny wee bit slower acceleration, but once you're in 7th, its all the same.
Old May 19, 2009 | 10:47 PM
FKD's Avatar
FKD
09 E350 4Matic Avant Garde, 07 BMW 335i Cabriolet M-Tech
You meant 5th? Only the E320 BlueTec and AMG come with 7 speed, the rest are all 5's.
Old May 19, 2009 | 11:20 PM
AMGTestDriverNJ's Avatar
86 190E 2.3-16v, 92 500E, 03 CL55 AMG, 08 E3504M Brabus
death to the 4matic 5spd I hate it! However, I don't think that is true. I'm pretty sure 7spds are available in 09 model 211 4matic's and I know its available on say an 09 ML 4matic and so forth. Anyway, you may want to start with something simple like checking your air filters and maybe a fuel injector cleaning would net you some higher mpg numbers. And yes, driving in C starts the car in 2nd rather than 1st which obviously burns less fuel. GL
Old May 20, 2009 | 11:02 AM
Barry45RPM's Avatar
2015 ML 350
In your case yup. 5th. C eliminates 1st gear & moves the shift points so the car doesn't hold gears as long as it shifts its way up.
