Alignment/ Camber question - how low before camber kit?
Im new to the forum and own a 2004 E500 4matic...awesome car- but terrible drop
I've doing a ton of reading here, and i'm about to bite the bullet on lowering links to drop it slightly.
My question is, how low can i go before having to buy a camber kit?
I would like to have about 2-2.5 finger gap all around (with E63 staggered rep wheels)--so about an inch drop in the rear and slightly more in the front.
Basically, I think the car drops 1" all around when at freeway speeds. Whatever that drop is, is what I want to do because if no camber is required for that drop at freeway speeds, surely it can't be required at slower speeds? Maybe my logic is flawed.
I ruined 3 sets of tires by not doing a camber kit within 10000miles! First the original tires, then my winters & finally my 18's. The camber was a -2.2, you wouldn't think that's too much, but it destroyed the inner edges of my tires. The delay in came in finding someone to install the K-mac camber kit. I finally decided to do it my self. Wow...that was a tough job, but it remedied my tire problems.
Just do the camber fix ASAP.
Good luck
Rear camber kit is from K-mac (~$350 + install if you don't want to DIY), http://www.k-mac.com.au they are bushing replacements with adjustment, not super hard to install, but you need to take a bunch of stuff off and deflate the rear suspension in order to put them in. Its a long job and you need all the right tools and a lift to make it easier.
Fronts are from the dealer, they are called alignment repair bolts (or something like that), they are basically the same bolts used on the front suspension, but with 2 long grooves that allows you to dial in positive camber on the front suspension. They are around $10 each if I recall, you need 2.
But yeah, I might wait on lowering until I'm ready to blow over $1k on lowering the car via SDS or links + kit.
(still owes for last two bills) this is why we are asking this question instead of ordering the kmac kit! The rear camber is out and wearing tires quickly and was wondering if it is possible to grind off the nubs where the rear lower control arm bolts go through? There is a slot that we could adjust the camber if they were gone but was wondering if it would move while driving or over potholes? Thanks.ps, it is stock not lowered and could not find anything bent, worn out or sagging.
