How can i reset service indecator
Am owning E-240 model 2004 - Last time i had did changed engine oil my self "Not in the Agency" - ofcourse after changing it i was not able to reset it and am still having this message "Service A Exceeds by ......" and there is a message "Engine Oil Level -Not when engine on"
Now it reaches 3802Km and The engine light had come on my taplo
So how can reset this service indecator to avoid these annowing msgs ?
If you read your manual, it explains how to read the engine oil level. Engine oil is supposed to be checked once the engine has been switched off for a few minutes first.
Do you mean the check engine light comes on, not only the service reminder? Sounds like you have some real issue with the car, not just the FSS reset to be performed.
In any case, you can find links from this forum showing how to reset the service indicator, there is a sticky too and the info is available from Star tekinfo too.
https://mbworld.org/forums/1902437-post34.html
