My mothers E320
She needs a tuneup.
Care to let me know what she needs? Here is what I am going to do:
Plugs, air filter, cabin filter
Anything else?
Also, it was running a little sluggish at lights and the CEL came on and the code was P0171. Should I just clean the MAF sensor? It only has 55k miles on it. I hate to replace it. Its $200 or something correct?
Lastly, where do you guys buy your parts? Let me know the link so I can order these.
Thanks for your help.
Fuel trim bank one condition
– The powertrain control module uses the oxygen sensor to calculate the air/fuel ratio of the engine. The computer has recognized a rich or lean condition on one engine bank only.
Probable Cause[s]
1. If bank one and two codes set together suspect fuel pressure or MAF (Mass Air Flow) Sensor
2. Oxygen sensor defective
3. Ignition misfire-repair
4. Fuel injector problem
If you do clean the MAF use the cleaner that CRC makes.
Regards,
paul...
