E-Class (W211) 2003-2009
COMAND nav versions
Old Jun 10, 2009 | 12:41 PM
TOMORO's Avatar
2006 E350 4MATIC
COMAND nav versions
Hi, I have a 2006 E350 with the comand nav, HK system. I have read a bunch on the forum about the disc versions so I popped mine from the trunck DVD player and it is 2005.3 BQ 6 46 0209 Also says: MY04-MY06 E & S Class
My questions are:
1 How far behind is my nav?
2 Would an upgrade improve the look/feel of the nav? What would the benefits be?
3 Is it a single disc (map disc) or do I need a service tech to upgrade the head unit too.
4 Is there an upgrade (software/firmware) to the COMAND head unit?
5 Best way to accomplish upgrade(s). Where to get materials.
I appreciate any advice, I know this topic is popular here, I hope you guys can help.
Thanks, TOMORO
Old Jun 10, 2009 | 01:38 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
No flame, but your questions on this topic have been addressed numerous times. Please search.
Old Jun 10, 2009 | 02:39 PM
Barry45RPM's Avatar
2015 ML 350
There will be virtually no difference in the performance or look. Only new roads/hiway mods/POIs will be updated to display what will then be year old information.
If you feel the Nav info is "outdated", I'd have the dealer install the new disk & update the head unit software at the same time. That way you will eliminate conflicts of software in the trunk and dash, since it will be your 1st update. If they note a problem they'll make sure everything is updated. You'll also now have the option to display ETA to your destination at the bottom of your screen if your car doesn't already have that option. These NAVs are not cutting edge, but the will get you there.
These cars are finicky when it comes to updating anything. My policy is not to update unless necessary. You'll find that you won't need to update the NAV disk again unless you live in a rapidly developing area. I had an '04 & then an '07 & the look & feel between the 2 are the same. There is only 1 DVD in the trunk for all available map coverage.
Welcome to the board. Have a look around & hang out!
