Rear Camber Issue?
The lovely, helpful (sarcasm), MB of Palm Beach mechanic today said it was beacuse the car was not designed for those wheels/tires. That the suspension on the e550 is desined differently. I should put my 16s back on.
I also had new rotors fitted all round (2 grand!!) a couple of months ago.
My questions are:
1) Is anyone else running wheels/tires like mine on a similar car? What is your experience?
2) Can you adjust the rear camber?
3) Could is be due to poor fitting of the new rotors?
Thanks,
Carl.
I stuck with my 16" (reluctantly) for two reasons. One, that the dealer does not recommend a larger size and two that custom wheels 21lb-23lb in 18" with tires would cost around $8K or thereabouts. I would have ordered but decided to wait till I heard other reports. Yours is the first I've heard where a larger wheel size on a Bluetec has technically failed.
Having said that, inside tire wear, as correctly diagnosed by you is due to (now induced) negative camber and too much toe out. With the Bluetec in particular, use of larger wheel size requires addition of a rubber stop, to prevent excessive suspension travel, yet another cause of uneven tire wear.
Hypothetically it is possible to use an 18, 19 and even a 20 inch rim (in a Bluetec) if it is followed by perfect wheel alignment.
Watch out for the following:
1. Rubber Stop
2. Negative Camber
3. Excessive Toeout
4. Too much Tire Pressure
Sooner ot later I will definitely experiment with at least 18" wheels
My questions are:
Thanks,
Carl.
1. Rubber Stop
2. Negative Camber
3. Excessive Toeout
are you saying use high tire presure?
also i ordered a set of H&R springs already for the car.
Rather than repeat what has been said before, the link below explains it all.
https://mbworld.org/forums/e-class-w...heel-size.html
