E-Class (W211) 2003-2009
Loud Wipers????
Old Feb 13, 2003 | 09:36 PM
mike_fern2001's Avatar
2000 audq a6
Loud Wipers????
Does anyone else find their wipers on the e500/sport to be extremly loud- even when their is plenty of ater on the windshield?
Not the motor- but the "drag" over the glass?
and did anyone figure out a way to correct this?
Old Feb 13, 2003 | 10:06 PM
gobenz's Avatar
I drove over 100 miles in the rain last weekend. My wipers were very loud...same problem - noise dragging over the windshield.
Hopefully someone will have an answer to provide relief from the annoyance.
Old Feb 13, 2003 | 10:47 PM
gary_hgy's Avatar
2003e240
Same here. Complained to the dealer and he just 'polished' the but the noise is still there. I am asking that he change the wipers in my next visit. It is quiet on the first two sweeps but gets very noisy, skidding, jummping over the glass after that.
Old Feb 13, 2003 | 10:49 PM
mwillems's Avatar
2009 ML320 CDi Bluetec
Solved for me
Mine did same but after dealer repalced blades twice, all OK. Hard dubber used as standard amd that is too noisy (but lasts longer perhaps)/
Mike
Old Feb 13, 2003 | 10:59 PM
jabo's Avatar
E500W '03, Porsche Cayman S '06
Might want to try RAIN-X
If you apply RAIN-X to the windshield it is less likely to squeal.
Old Feb 14, 2003 | 11:44 AM
marc777's Avatar
2012 CLS
I have driven my car for 4500 miles and complained about the noisy wipers from Day 1. See earlier posts.
Yesterday they were replaced by the dealer - AND WHAT A DIFFERENCE!!!!!!!!
Simply get them changed - there's no design fault - mine are now blissfully quiet...............
Marc 777
E270CDI, Avantgarde, Silver, pano roof, 17" wheel upgrade, sports suspension, folding mirrors, split rear seats, full grey leather
Old Feb 14, 2003 | 05:47 PM
2000 audq a6
wiper
did u have just the blades replaced or the wiper unit?????
tks and tks
Old Feb 15, 2003 | 03:00 AM
marc777's Avatar
2012 CLS
The whole unit
Marc
Old Feb 15, 2003 | 03:02 AM
marc777's Avatar
2012 CLS
......by the whole unit I mean the whole wiper blade - not just newrubbers fitted.
Marc
Old Feb 15, 2003 | 10:56 AM
Leslie's Avatar
Yes
LOUD!
LC
Old Feb 15, 2003 | 11:50 AM
etenn's Avatar
E-500
Dealer changed the "rubber units" only on mine. Now very quiet.
Old Feb 15, 2003 | 09:10 PM
RJC's Avatar
RJC
Various
My wipers are quiet on my clk 500 but the drivers side is missing an area in the lower and middle section...anyone experience missing spots?
Old Feb 15, 2003 | 09:53 PM
mwillems's Avatar
Missing area
On my E320, left hand side of the windscreen, lower area - JUST where I look - is not cleaned properly on salty roads. It's design - even the 3rd set of blades does this.
Michael
Old Feb 15, 2003 | 10:38 PM
RJC's Avatar
RJC
Various
Re: Missing area
Michael
How about in the rain?
It could be the wiper arm needs replacing...needs more pressure against glass in that area???
Old Feb 16, 2003 | 08:30 AM
mwillems's Avatar
Wiper
How about in the rain? It could be the wiper arm needs replacing...needs more pressure against glass in that area???
In the rain it is OK. The problem is not pressure. The problem is that the water you spray onto the windscreen is not distributed properly, and there is no way to aim the two water jets that actually guarantees proper distribution. When my car was in the shop and I had a rented Toyota, it was amazing how much better that worked whenever I sprayed the windscreen.
Anyone else driven an E320/E500 in Canada on salty roads where you need to spray to keep your window clean? Was your experience the same?
Michael
Old Feb 16, 2003 | 10:22 AM
jabo's Avatar
Aiming the water jets
I read an earlier post where someone mentioned
using a toothpick to aim the jets.
A sewing needle might also work well.
Old Feb 16, 2003 | 10:25 AM
mwillems's Avatar
Aiming the jets
If I aim the jets elsewhere, some other area will beleft wiping dry. It's the entire design of jets/wipers/windscreen, I think. Only obvious when the roads are salty or very dirty and you need to spray to keep them clean.
Michael
Old Feb 16, 2003 | 10:32 AM
jabo's Avatar
Yes, I've notcied that too
We have regular snow and salt here in Chicago, and I have noticed this as well. I don't think we have it quite as severly though as you might in Canada. For what we get down here, the coverage seems adequate with the four nozzles distributing the spray.
Right after it snows though, the stuff that other cars kick up from the road keeps the windshield covered and forces you to frequently respray/wipe the windshield.
My only other remedy is to avoid following too closely.
Old Feb 16, 2003 | 01:05 PM
monakh's Avatar
I have this problem with keeping the windshield clean, as well. And yes, my wipers are dreadfully loud. I have to keep spraying to get my windshield clean, but at times when it is not raining hard enough, I get this ugly half-circle of lines, that seems to freeze on the glass. I live in DC, and I know it is not because it is too cold. Besides, it only exists on the driver's side of the windshield.
Old Feb 16, 2003 | 03:25 PM
mwillems's Avatar
You too eh
Yes, so this seems another little design anomaly. Well, it's one I can live with, though if anyone (or MB!) solves it, let me know.
Michael
Old Feb 17, 2003 | 08:36 PM
MadManAboutTown's Avatar
2004 E500
Had mine replaced by the dealer when in for the motor mounts swap, now very quiet (both the engine and the wipers).
Old Feb 17, 2003 | 10:55 PM
RJC's Avatar
RJC
Various
What was your cars production date? How loud was the sound from the motor mount issue? Did your wipers miss an area of the windshield? Were the blades replaced or arms too?
Old Feb 18, 2003 | 06:15 AM
2004 E500
Car was available from factory in mid-November with a distinct diesel sound from the engine while accelerating below 3500 RPM which is specifically addressed by an M-B service bulletin.
Wipers were rubbing hard on the driver's side at the top of the stroke; just the blades were replaced to by knowledge to correct this problem.
