E-Class (W211) 2003-2009
Operating the Comand System
Old Jul 30, 2009 | 09:37 PM
Transbug's Avatar
E350
I just traded my '04 545i BMW for an '07 E350 CPO. A stark difference in power, but I got just what I wanted in the E350. My question is how do I get the voice comand to work. I have gone in an individualized the system and saved both of the 2-step process. Can someone now tell me what I should do next in order to get it to work.
Old Jul 31, 2009 | 03:35 AM
Diesel Benz's Avatar
Did you read the manual (for voice control/Comand)? Shouldn't it be sufficient to just press the voice control button shortly at the steering wheel and start talking? Try "help" first if you are shy.
Old Jul 31, 2009 | 03:47 AM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
Wait W211's have voice control? Do the '06's have it as well?
Old Jul 31, 2009 | 04:06 AM
I assumed he was talking about a W212 at the 212 section. Now that I realise it is a 211, voice control must be activated from a separate stalk close to the steering wheel.
I don't know how it is with US cars but voice control is an option in Europe also for the W211 (any model year).
Since it is a W211, the features may not be explained in the Comand manual, a separate manual should exist then.
Old Jul 31, 2009 | 05:04 AM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
2009 W211s have 'enhanced voice control' as standard equipment. Works quite well and makes the system basically hands-free. In the US, everything is explained in the additional COMAND manual that accompanies the owner's manual.
I think in 2006 it was an option(?) As DB says, it's activated by a stalk on the right side of the steering wheel.
Anyway, the OP needs to ask this in the W211 forum to get the answer.......
Old Jul 31, 2009 | 06:16 AM
Transbug's Avatar
E350
I appreciate the info and the education on W212 vice W211. The comand system manual doesn't really give any instruction on the use of voice comand. I'm certainly to exhaust all means available to me before bothering others. I'll got to W211 block to see if I can get the info.
Old Jul 31, 2009 | 10:10 AM
Barry45RPM's Avatar
2015 ML 350
It is an option called VCA. If you have it, there is a thin Cruise Control type of stalk sticking out of the right side of the column. If you don't have it, you have a bump there with a plug in the hole.
Old Jul 31, 2009 | 10:12 AM
Barry45RPM's Avatar
2015 ML 350
This IS the 211 Forum. He's in the right place.
Old Jul 31, 2009 | 10:28 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
It is now after I moved it. It wasn't at the time of the response.
Damn mods and their communication skills.
Old Jul 31, 2009 | 10:33 AM
It is in the right section now. The thread started at the 212 section, a mod must have moved it to the right home.
Anyway, I have a copy of a separate, specific VCM user guide. Can it be part of the Comand manual too?
Edited: OK, I see while I was typing, amdeutsch explained what happened to the thread...
Old Jul 31, 2009 | 11:10 AM
MB211's Avatar
2005 E500, 2011 ML350
Pull the stalk towards you, after it beeps say "Help", it will list available commands....
The voice control before Laungtronic (NGT2.5 or newer) is somewhat useless. You can basically say radio, cd, navigation, station number, say a phone number, or store a voice tag (like older cell phones). It will not reconize a name and "read" it from the phone book. It is completely useless with navigation commands....
Old Jul 31, 2009 | 11:57 AM
konigstiger's Avatar
'71 Pinto
PM your email address and I forward the MY07 VCS operation guide.
Old Jul 31, 2009 | 12:40 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i mainly use VC stalk for phone use... voice recognition of numbers is just amazing...
Old Aug 1, 2009 | 12:28 AM
Transbug's Avatar
E350
I finally figured out the basic operation of the voice comand, now it's behaving exactly the way you just explain. When I instruct it to call a name, it only goes to the first name listed in the phone list. Is it difficult to install the Loungtronic NGT2.5 or newer versions?
Old Aug 1, 2009 | 07:23 AM
K-A's Avatar
K-A
Ahh, thank you, THAT'S what that stupid rubber thing is on the right side of my steering wheel.
Old Aug 1, 2009 | 10:30 AM
Barry45RPM's Avatar
2015 ML 350
Have you recorded a name associated with a phone book number into the COMAND head unit first?
On the command scroll thru the phone book, select a name, then using the comand soft keys record the name into the head unit. Mine works all the time.
Old Aug 1, 2009 | 12:07 PM
Transbug's Avatar
E350
I did that and it still just go to the first name in phone list. I'm going to reset is and start from scratch and what happens then. Thanks for the info...I'll post the outcome of my starting from scratch attempt.
