E-Class (W211) 2003-2009
Help me Please im a newbie...
Old Aug 6, 2009 | 12:45 PM
dsm2925's Avatar
W211
i got a 04 e500 .
i cant find the motor oil dipstick. i fould thr trans oil dipstick but it has no stick.. Did it fall inside the tranny?
trans shifts great..
thanks guys... i love this place..
Old Aug 6, 2009 | 01:51 PM
lkchris's Avatar
'10 CL550, '12 GL550
Car did not come with either
check motor Oil on dashboard
check trans fluid with special tool
Old Aug 6, 2009 | 03:43 PM
MercFiveHundred's Avatar
2014 E550; 2003 E500
There are two dipstick tubes - one for oil and one for tranny. The one i think you are talking about is the oil tube - but it doesnt come with a dipstick. The tranny one is below that one and you have to remove the air filter housing to see it. The cap on the tranny tube will also let you know that that's the tranny.
Old Aug 6, 2009 | 03:53 PM
Flash Gordon's Avatar
2003 E500, 2004 G35X
To check your oil level, you need to go to the controls on the steering wheel with the engine off but the key on ignition. Follow the steps on the dash in front of you. The oil level readout will not tell you the quantity level of the oil, only that the level is OK.
Old Aug 6, 2009 | 03:54 PM
dsm2925's Avatar
W211
thanks for info... so even if i find the tube i wont be able to measure the motor oil?
Old Aug 7, 2009 | 12:03 AM
lkchris's Avatar
There's a special tool for this, too.
The tool cannot be permanently installed, just used to measure oil.
The dashboard readout method works just fine and it isn't worth it to get the special tool. This is no problem, really.
