E-Class (W211) 2003-2009
avg and range display
Old Aug 8, 2009 | 12:16 AM
esssevo's Avatar
2006 e200 ngt
hi, i've got a 06 w211 ngt, and it doesn't show range and avg fuel consumption. is it possible to get it displayed?
Old Aug 8, 2009 | 03:47 PM
GGM's Avatar
GGM
2008 E350
I am going to assume that an E200 as seen in your profile means that you are not in the USA. You may want to post more information that shows where you are so someone from your part of the world can help you. I don't recognize an E200 nor the ngt designation. E's in the US are either E320, E350, or E550 depending on the year and whether or not it is a diesel. The more information you can post about your car and your whereabouts, the better the members can help you.
Hope this helps.
Old Aug 9, 2009 | 02:49 AM
Diesel Benz's Avatar
I think 06 W211 NGT and E200 NGT say everything about the car. US members may know about it equally as European know the US model specifics.
Anyway an interesting point, I assume the problem for the cluster is to handle both the range available with gasoline and natural gas. The average fuel consumption is usually measured from the injection time which gives an accurate measure of liquid spent. Natural gas would need a different sensor, perhaps the only info the car has is if the gas reservoir is empty or not. I don't know how the gas reservoir content could be measured except from weight and that is not practical in a car. Pressure does not tell the right thing.
Now if they cannot show the "fuel consumption" for natural gas, I assume for consistency they don't show it when the car is driven with gasoline even if that was possible. I hope you get this confirmed by other owners of a similar model.
