E-Class (W211) 2003-2009
Tire Pressure Monitor
Old 04-25-2010, 03:23 PM
DanG2's Avatar
04 E500
If the sensors worked OK with your old wheels it seems unlikely that it would be necessary to buy new ones. How did you determine that the sensors are leaking? Did you submerge the wheels or spray them with soapy water and see bubbles from that area?
Go to Post #19 above and click on the link. Pages 10 and 11 show the sensor and valve components. The sensors themselves are epoxy-filled, so they will not leak. There are only two places where you might be losing air. One is at the gasket at the bottom of the Valve ( Page 11 Item 2, sometimes referred to as the valve stem). That would cause bubbles to appear outside the Valve stem at the bottom. The other is the Schrader valve inside it. That would cause the bubbles to appear inside at the top.
Seems like at worst you might need new Valve stems, not new sensors. If you're showing leaks at the bottom of the stem, it may be that the lock nuts just weren't tightened enough. I'd try checking that first.
Old 04-25-2010, 05:59 PM
valiance's Avatar
CL500 2003
Thanks for reply. I have determinate that sensors are loosing air because before installing it not leaking. I´ll check these points that you have mentioned. Thx!!
Old 12-12-2010, 10:47 AM
pelletman's Avatar
2004 E500
For those who haven't seen it, there is some training material for the system at http://www.mercedestechstore.com/pdfs/W211_technician/319%20HO%20TPC%20(GC_RP)%2006-20-02.pdf
I think it will answer most of the questions, except for the ones about costs.
What does this mean? What is DAS? Is this accessible from the menus on the steering wheel?
When using wheels without pressure sensors, deactivate TPC using DAS (“control
unit adaptations” > “read coding and change if necessary” > “monitoring function” >
F2 > select “not active”, then “transfer coding into control unit”.)
Old 12-12-2010, 10:54 AM
Mackhack's Avatar
That means you would need a SDS (star diagnosis system). DAS means diagnosis assistant system.
Has nothing to do with your steering wheel buttons.
Old 12-12-2010, 11:02 AM
pelletman's Avatar
2004 E500
Bummer..
Old 12-12-2010, 11:06 AM
Mackhack's Avatar
Originally Posted by pelletman
Bummer..
Why? What do you wanna do?
Old 12-12-2010, 11:38 AM
  #32
pelletman's Avatar
2004 E500
Put winter tires on that don't have the TPM's in them. Trying to avoid buying them...
Old 12-12-2010, 11:54 AM
  #33
Mackhack's Avatar
Dealership can diasable it in less than 5 min if they know how to.
Old 12-12-2010, 12:10 PM
  #34
pelletman's Avatar
2004 E500
and if you can find one to do it...
Old 12-12-2010, 12:14 PM
  #35
Mackhack's Avatar
I would if your in socal
Old 12-19-2010, 08:57 PM
  #36
ap10046's Avatar
CLS500 M113
Originally Posted by Mackhack
It was mentioned so many times that it is expensive to retrofit the system on a car that hasn't been shipped with one. But how much is it actually???
+1.
Really, How much is it??
Old 12-19-2010, 09:07 PM
  #37
Mackhack's Avatar
I really hope we get an answer on this one one day. Steve did so many installations here
Old 02-08-2011, 11:35 PM
  #38
lmichael29's Avatar
ML-550,Slk-280,R-350
SUV
What is length of ML-550 battery in normal usage?Does this affect tpm
Old 02-08-2011, 11:37 PM
  #39
Mackhack's Avatar
What???
Old 02-09-2011, 06:29 AM
  #40
UK-C200's Avatar
RHD C200 Sport Coupe, RHD SLK-55, LHD SLK-350
Trivial to retrofit HighLine TPMS to your car, most expensive bits are the sensors themselves. Control module is cheap - like $150 us..
Quick Reply: Tire Pressure Monitor
