Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes-Benz E-Class: How to Repair Power to the Trunk
Step by step instructions for do-it-yourself repairs
No power to trunk, 3rd brake light, or license plate lamps
#151
The reason for this problem
I just fixed this on my 2008 E350 4matic keyless go. There are two reasons that the brown wire is the most likely one to break first. 1. That wire is a common return ground for all the circuits, therefore it is thicker and stiffer than the smaller supply wires adjacent to it. MB chose to use a very stiff wire type for this that is less able to handle the repeated bending stress. The smaller wires are more flexible. 2. The bending forces are concentrated over a very short length due to a bad design. The large plastic cover over the arm ends right where the flexible plastic wire shield starts. That flexible corrugated wire cover should have extended farther under the plastic arm cover. MB's design allows the wire bundle to flex far too much at that stress point. When the trunk opens and closes all the wire bending is concentrated at that spot instead of being spread out over a longer length of the wires. I did two things to address this. First, I spliced in a short extra length of flexible multi strand copper wire to create a more resilient joint. Second I added another loose wire tie around the corrugated wire bundle cover at the point where the trunk gear bracket and spring attach to the arm. This prevents all the bending from happening at the point where the wires leave the plastic plastic arm cover. I left this tie loose so the wire bundle could slide and not create a new sharp bending point . This will spread out the bending arc of the wires over a longer distance. Understanding the cause of a problem helps engineer a longer term fix.
benz_driver (01-04-2024)
#152
No rear lights
[QUOTE=hbamark;3694210]Hi All,
If your vehicle has lost power to the trunk unit, and lights, there is a very simple fix. This is fairly common problem on W211 models. The wires get caught it trunk hardware and get severed. The dealer wanted to charge me $250 for something that took me 20 minutes and less that $10 to complete. Here's what I did.
1. Use the key to manually open the trunk.
2. Remove two plastic pins holding carpet/panel on the driver side of trunk. Pull carpet/panel away carefully.
3. Remove plastic cover on left trunk hinge by unfastening pin at top of cover.
4. Follow the wires until you find where they are severed.
5. Strip wires slightly.
6. Put a piece of shrink tubing over one side of the wires.
7. twist severed wires back together where you stripped and exposed the copper.
8. Solder the wires.
9. Pull the shrink tubing down over the exposed copper.
10. Heat the tubing so that it shrinks around the exposed wire.
11. rewrap wire so that it follows the left hinge in a manner that is will not get cut again. (I wrapped the at risk area in duct tape, not pretty, but it was effective).
12. Reinstall Panels.
Sorry for the lack of pictures, but this is a real easy fix. I hope this procedure saves some $$$ for someone.[/QUO
i have no power to any rear lights or trunk release can’t find any broken wires
#153
2003 SL55, 2006 CLK500, 1998 Vette
Can someone point me to what gauge wire this is (specifically the brown ground) and where can I pick some up? I need to add a piece of wire to extend it a bit but figure out the gauge.
#155
#156
#157
Received 1,495 Likes
https://www.homedepot.com/p/Ideal-Sp...342S/202894306
#158
#159
Not Helped 🤔
Hi All,
#160
better way to fix
Hiya, I have done all this following installation of a new Rear SAM unit and the switch on the drivers door stays red preventing the boot (trunk) from closing. When I separate the brown wires again the boot closes but 3rd brake light is then out. I’m guessing there’s a short circuit somewhere so any ideas please?
Alandbecca (11-08-2022)
#161
Re:No power to trunk, 3rd brake light, or license plate lamps
Quick fix for W211 models with trunk power and light issues. Manual trunk opening, remove panels, find severed wires, strip and solder them, use shrink tubing, secure wiring, reinstall panels. Saved me money, hope it helps someone else! I experienced this myself and the dealer quoted me $250, but I managed to fix it in 20 minutes for less than $10. Here's what I did
#162
CaliBenzDriver (08-05-2023)
#164
Thank you hbamark:
Had the same symptoms of "no 3rd brake light" and had to use the key to get into the trunk.
The brown wire was completely severed.
Easy fix once you know what to do. Thanks again
#165
It worked but....
I had the broken wire and it fixed my license lights, third break light and now the motor on the lock makes noise, but the trunk will not open with fob or door button still - everything else fixed when the brown wire was re-attached. Could there be something else?
#166
check for another broken wire.
#168
#170
Hi All,
#171
99 CLK 430
Thank you this fixed it
Thank you so much. I was looking at the fuses and although the cigarette lighter one was popped in the trunk The one to open the trunk was fine. I followed the advice kind of except for I just ripped the plastic piece off of the arm to the trunk because I was mad because I had no third brake light or license plate lights and my trunk was not opening and I had to go to the store and it was 11:00 at night. I looked for the brown wire and sure enough it must have already been repaired already very poorly with some cheap wire crimp and the wire was completely out of it so I fixed it and everything works now.
