E-Class (W211) 2003-2009
help needed with brakes and engine
Old Sep 2, 2009 | 01:39 PM
leku's Avatar
E 220 CDI(English side)
Exclamation help needed with brakes and engine
1- please somebody help me, i have a "w211 2002 220 cdi" every time i pres brake pedal something inside the cover of the engine on the left side of the car(passenger side) makes a noise like a squosh or smth like water or air. brake fluid is ok. i just checked. i think it is abs.
2- i just changed my erg valve damaged due to air collector block by dirt. after one week the engine started to work like a truk, the engine calms down when turbo is in work. dont like that noise.
just had a computer diagnosis of the car but it says that every thing is ok.
at mercedes benz work shop in Albania they told me dont worry, byt they are dump people so please help me
Old Sep 2, 2009 | 02:07 PM
AmazinglySmooth's Avatar
E500
I have the same sound as your problem #1. I don't know the answer yet, but it doesn't appear to impact the braking performance. I'm having it looked at on Friday.
Old Sep 4, 2009 | 02:38 PM
leku's Avatar
problrm #1 identified...abs failure. the guy sad dont move the car since it is done because it is very dangerous. €1'500 to buy a new one. the computer dont show nothin this is that makes me go mad
Old Sep 4, 2009 | 02:49 PM
E500
Did the dealer say what about the ABS would fail? Would ABS not kick in? Could this be tested by trying to brake hard?
Old Sep 4, 2009 | 05:29 PM
E500
Service contacted me and want to check for air in the brake lines. Is this common? They suggested it was for MB.
Old Sep 9, 2009 | 02:19 PM
leku's Avatar
I didnt have time to fix my probl so if u could tell haw yow solve it it would be very helpful
Old Sep 9, 2009 | 03:31 PM
Flash Gordon's Avatar
2003 E500, 2004 G35X
Air in the brake system will result in "spongy" brake pedal feel, not the kind of noise you encountered.
Old Sep 15, 2009 | 01:32 PM
leku's Avatar
anny suggestion of what it can be. i have to underline that nothing appears on the screen. no faults at all.
Old Sep 15, 2009 | 02:00 PM
konigstiger's Avatar
'71 Pinto
What you are hearing may be normal for the SBC hydraulic unit functional by opening a door, operating central locking system, depressing brake pedal, turning key to position 1, or operating the parking brake. You should know that a 10-year/unlimited mileage extended warranty covers hydraulic unit replacement if needed.
If air is in the system, you may hear a squeaking noise at the hydraulic unit when gently applying brake. Depress the brake pedal a short distance with minimal force at least 20 times if squeaking noise is heard and no fault codes are stored, SDS procedure will release air.
Old Sep 16, 2009 | 12:16 PM
leku's Avatar
u dont even imagine werw i am. just been to mercedes benz in slovenia. they dont know nothing about the warranty, or they wan't do it free. could u tell me sth more about the warranty pls. where can i find sth written to show them. daoes it work in europe???
Old Sep 16, 2009 | 02:38 PM
'71 Pinto
PM your email address and I will send info to support your claim.
