E-Class (W211) 2003-2009
wheel/tire question
Old Sep 18, 2009 | 12:17 PM
soccerg201's Avatar
GL550
wheel/tire question
I have a 2009 E550 sport with the staggered wheels. I was wondering if the wheels were the exact same dimension but they just have different tire sizes? Thanks for the help
Pat
Old Sep 18, 2009 | 12:45 PM
lkchris's Avatar
'10 CL550, '12 GL550
Most likely different sizes.
You can take one of each off and find the size cast in somewhere on the back side.
Old Sep 18, 2009 | 01:52 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
The back rim is wider unless you have a 4matic car, but then you wouldn't have staggered tires.
Old Sep 18, 2009 | 04:28 PM
taylor210's Avatar
02 E320 Blk, 09 E350 Blk
Pat
2009 E350 AMG PKG and E550, the wheels are staggered!
Front: 18 x 8.5, ET38mm, 245/40/18
Rear: 18 x 9, ET 39mm, 265/35/18
Old Sep 18, 2009 | 06:16 PM
soccerg201's Avatar
GL550
so its not just a differnt tire size on the same wheel? the wheel is actually wider as well? reason i ask is that the tire rack has 235/65 18 blizzaks for $99 a piece. I was just wondering if I couold use those up front as well.
Old Sep 20, 2009 | 02:25 AM
taylor210's Avatar
The rear wheels are 1/2 inch wider than the front. The tire 235/65 18 is way too tall for the front and will have rubbing issue...You may use size 235/45/18 up in the front and 255/35/18 for the rear.
Old Sep 29, 2009 | 07:28 PM
e50zero's Avatar
E500
235/65 is way too tall for the front...i agree you will have a rubbing issue
