DIY:Adjustable Camber Arms Install
2.Area on subframe where we remove bolt1(Requires alot of WD40)
3.Area on hub where we remove bolt2(Again alot of WD40)
4.Better image of work area(left rear of car)
5.Camber arms(Notice that the bolt design requires special tool but you can actually use same bolts in new camber arms).The only part that may be tricky is the part of the camber arm that attaches to the hub is tapered as well as the location where the arm sits is tapered inward..If you look at the hub for 5 minutes you will understand the proper location.
6.Installed pics
Very easy install just make sure you have the right tools before.
6.Installed pics
I have an 08 W211 - so I really need 4 camber bolts for the front? how hard it's to install the bolt? and do you set it when you install it or just install it and let the NTB alignment do the adjusting for you?
my front are -2.73 and -1.1 on the rear.
I need to get this bolts in or else I'm gonna need new tires.
