Retrofitting TPMS sensors
Does anyone know the part numbers I need to retrofit TPMS sensors and receiver into my car and how to get it to display on the MFD? I saw some post it's about $240 to get them retrofitted but I don't know where to order them and how to enable them in the MFD.
It will cost you more than if you had ordered it from the factory & only a few people are willing to tackle the job.
You might consider these: http://www.amazon.com/Tire-Alert-Sel.../dp/B0009RSR36
(You inflate the tires to the desired pressure, screw these caps on and they instantly memorize that pressure one time, forever. Whenever the pressure is 4 lbs below the memorized pressure or the caps are off the car, the LED in the cap blinks red. Put air in the tire & the blinking stops.
The Siemens system for a 2007 car is a bit simpler than the older Beru with an antenna for each wheel but it still needs quite a lot of wiring plus the control unit.
Has anyone actually done one of these? I really like to know a ball park amount that I am looking at.. I certainly don't want to spent more than $500-$600 for a complete system. Barry, did you remember how much it cost as an option when you ordered your car?
Did the Wifes W211.It requires a LOT of labor to fit the wire harness...
Along with a set of rims fitted with sensors..then version code the vehicle via SDS ...Re the Price the TPMS sensors alone will cost more than the 250/350 range
As an example, for US W211, ATA, Airmaric hoses, TPMS, Keyless Go, and the main chassis harnesses was one gigantic pile of cables weighing approximately 80 lbs.
