E-Class (W211) 2003-2009
E Class Main Battery Replacement
Old Oct 23, 2009 | 02:17 PM
jimbo1mcm's Avatar
All Diesel Fleet !1983 240d stick,2005 E320 CDI Midnight blue, 2005 E320 CDI, Desert Silver, Kubota
I just purchased 2 Deka 9AGM49 batteries for my 05 CDI's. The battery is manufactured with silver calcium and is warranteed for 70 months. It has 900 CCA and sells for around $145, plus or minus a few dollars. It is an exact fit for the MB battery which is well north of $200 each. It was also designated as a K9, meaning it was manufactured for November 09, so it is very fresh. While time will tell if it meets the same standards as the MB battery, it has a very good reputation. Made in USA.
Old Oct 23, 2009 | 07:04 PM
Clinton Horn's Avatar
2003 E320
$105 With exchange. Has proper vent for 2003 E320 anyway
36 month free replacement
96 months prorated
print this page
Related Documents
MSDS
Product Specs
Part Number 34-770B
Group Size 34
Description Bosch S5 (Pep Boys)
CCA @ 0F 770
Ca @ 32F 950
RC min @ 25A 120
Length in Inches 10-3/16
Width in Inches 6-13/16
Height in Inches 8
SKU# 9081253
UPC# 02885155815 0
Bosch 36/96 Month Battery
Part Number: 34-770B
Manufacturer: PB/BOSCH
Broadview, IL
708-865-5200
Old Oct 24, 2009 | 03:36 AM
jimbo1mcm's Avatar
Size?
Not sure what size the 03 E Class takes, but the 05 CDI takes a Group 49 AGM type battery and is not vented.
Old Oct 24, 2009 | 09:23 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Deka makes an excellent battery. Use them in my boat and I get 7 years out of them and all others I have used last no more than 5 years. Should be fine in your E Class although I use only MB batteries in mine.
Old Oct 25, 2009 | 05:02 PM
Long Islander's Avatar
2018 E400 4matic Wagon
Glad that worked out. And the Deka battery is fully sealed right?
Old Oct 25, 2009 | 05:39 PM
jimbo1mcm's Avatar
Sealed
Battery is AGM and fully sealed. It is an exact fit replacement. It even has the small hole that allows the small vent tube that is on the original battery to fit into the DEKA battery. Remember to re-set the sunroof to auto by holding it open for a couple of seconds then closed. Same with the windows. If your clock is synced to your command, after the ignition is on and the car can see a Satellite, it will automatically re-set the clock.
Old Oct 29, 2009 | 06:15 PM
jdupa's Avatar
06 E350
I was told by a local dealer that the 9AGM49 DECA is the direct replacement of the original MB battery. It just gets MB "rebranded" before it reaches the stealership shop to be sold for substantially more. Some additional info can be found here:
http://www.dekacatalog.com/
Old Oct 30, 2009 | 04:08 AM
jimbo1mcm's Avatar
RE-Brand?
Not sure about that. The MB battery case is white plastic compound and the DEKA is black. The DEKA 9AGM49 shows 900CCA while the MB shows 850 CCA.
Old Oct 30, 2009 | 08:45 AM
paulv's Avatar
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
Your doubts are right on target -- the MB OEM battery is made by Johnson Controls in Germany, and they're not sold in the US. Found this out when I called Johnson and they recommended going to the Napa/Deka battery when my main battery was testing low and I needed to replace it. My local Napa charged me $215 for the battery.
Regards,
paul...
