Tinting Shops in San Diego
2009 E350 Arctic White AMG Sport package W/ P2 option, 2002 C230 kompressor Coupe
Hi, I am looking for a tinting shop here in San Diego with a good reputation. I currently have tinting only in the back. My main goal is to have the back window tint remove and new tinting install.
This leads to my questions on quality and tint type. The current tint has lines not visible from outside but in the rear view mirror. Will new tint fix this small but very annoying defect? I am sure I will have to replace all back window tinting due to color matching of the old, not sure.
I have read other postings about ceramic tint and is it worth the cost?
The car is a CPO which already had the tinting completed.
Thanks,
Ray
Thanks,
Ray
2005 E500 Sport
Hey Ray,
I can recommend the StereOutlet in Pacific Beach 858-581-2434. Just had my E500 done there three weeks ago and was VERY impressed at the careful and detailed effort made to produce a first rate - show quality job. The price was extremely competitve! PM me if you want specifics.
2005 E500 Sport
Ray,
Sorry - hit the send button to quick... Didn't answer your questions... Using ceramic tint is not recommended on our cars as it potentially interferes with the radio antenna (embeded in the glass) performance. There are plenty of good film products available that will eliminate the UV / heat damage to the interior and provide a superior look without using the ceramics. Replace your back window tint - so that the entire job is matched and can be warranteed - it only costs about $40 bucks to remove your old tint and prep for the new and the best part is that the new film can be applied as one piece on the back window. Mine came out sweet - no seems! The application was almost artistic!
Also - you probably will require felt to be applied to the side window scrapers to prevent scratches to the new film - do it - cost is about $25./door (requires pulling door panels to install - they do it no biggie!).
Rennlaufer,
Thanks for the info. I was already thinking about replacing all pieces but wanted to get some advise on which shop to use.
Ray
Ray
I don't think thats correct. Ceramic is fine. Its metallic that is the issue. Ceramic is GREAT actually and I highly recommend it. search for "tint" on this forum for w211's .. lots of people have and recommend ceramic especially huper optik.
I go mine done at Hot SpotWindow Tinting
265 Broadway
Chula Vista, CA 91910-2319
(619) 476-1338
Call Danny for an appointment. I paid 145$. Life time warranty for bubbles, scratches, fading etc. He charges 20 $ in case you get a fixing ticket and you want him to re-do the windows.
265 Broadway
(619) 476-1338
2004 E320
There are only 2 shops in SD that do top notch work. They cost a little more than the those $150 tint jobs, but definitely worth it. You can't go wrong with either shops.
1st recommendation is www.sdtint.com Andrew will walk you through all the available films, shades, and even samples of their work. They push the film all the way to the edge of the window so you can't even see any gaps.
2nd recommendation is www.thetintsource.com Lou does awesome work also leaves no gaps on the window edges. Nice and clean!
Stay away from Tint Devil. That guy is a frickin rip off and cant cut straight!!!
Diamond Windows/Audio on Miramar Rd is another rip off! The guys there are fast, but they do half-*** jobs! 1/4" gaps and couldn't event cut it straight! Blemishes or specs of dirt in your tint and they don't thoroughly squeegee all the water out, which will eventually cause bubbles down the road.
@W211 Ryda that exact same happens with Hot Window Tint. He tells you everything first, shows you stuff and sample gives you an overview of what the different films do etc. Then he washes all windows to make sure they are dirt and grease free. He cuts it so there are absulutely no corners or edges left untinted.
So why paying more? He does a great job, no bubbles, no streaks or scratches no nothing. And his books are so full that you usually have to wait for 2 to 3 weeks to get an appointment.
Window Tinting
Thanks,
Ray
Thanks,
Ray
I recommend Tint Tech in Pacific Beach. They use Llumar window film. and also gave me a free bike rental while I waited. Got it done about a year ago and still looks awesome. Hope this was helpful.
I guess I have a little reviewing of the shops that have been recommended.
Thank you all for the feedback.
Ray
Ray
2009 E350
I got my ceramic tint at sdtint. Good guys there. The tint on my front windshield had little squiggles when I looked straight out. It wasn't super bothersome but I knew it was there. They replaced tint, no questions asked. I was told it's hardly noticeable but they did see it and my satisfaction was what was important to them.
