E-Class (W211) 2003-2009
PIC REQUEST: w211's slammed or lowered :)
Old Mar 17, 2013 | 07:52 PM
  #426
AMGAffalterbach's Avatar
2014 BMW M235i
You have an alignment done afterwards to get it as close to spec as possible? Looks good though. I'd go a little higher in the back or a little lower in the front to match. Definitely agree with 09W211.
Old Mar 17, 2013 | 09:51 PM
  #427
PepperE500's Avatar
2003 W211 E500
Originally Posted by 09W211
is that the lowest it gets? the front looks like it could go down a bit more, and probably even more with 19's or 20's. but looks good though
It will go lower. I need to get the Ordens on first before I start to fine tune. I doubt I'll change the height independently of front and rear because its lowered the exact same front and rear and I wanted to maintain that aspect.
Old Mar 17, 2013 | 10:35 PM
  #428
2014 BMW M235i
Personally I like the slightly raked look but it definitely looks good man.
Old Mar 18, 2013 | 02:39 AM
  #429
09W211's Avatar
2009 W211 E350 AMG Sport PKG
fuhh ordens would look dope. still debating if i shoudl pick up the set of euroline SL (pretty identical to ordens)
edit: just noticed the front bumper..brabus ftw
Old Mar 18, 2013 | 07:27 AM
  #430
PepperE500's Avatar
2003 W211 E500
I'm using the same ordens on the G35 on the previous page. You should pick up the SL's! I still have the brabus rear bumper to put on but I'm still planning out my exhaust.
Old Mar 18, 2013 | 12:26 PM
  #431
Craftysince86's Avatar
W211
Originally Posted by AMGAffalterbach
That is hella flush as they kids say these days. Careful man you look like your tires are about to shred and it's also illegal and if you scrape the bottom of the car your gas take will explode and your insurance guy will deck you and your mom raised you better than this.
funny you should say that, i have actually broken a gas tank before i'll find the pictures
pepper that 211 is looking real nice!
Old Mar 18, 2013 | 12:31 PM
  #432
09W211's Avatar
re-drilling them or running wobble bolts?
Old Mar 18, 2013 | 02:27 PM
  #433
PepperE500's Avatar
2003 W211 E500
Thank you! I got a small question for you. The front hub protrudes out a lot more than the rear. Is there a specific reason for that?
I bored out the holes to 5/8" and I'll be running wobble bolts. I have to rebarrel all 4 wheels since the E sucks for having deep dish. The pic below is the front wheel off of the G (19x9.5 ET -4).
Old Mar 18, 2013 | 04:11 PM
  #434
09W211's Avatar
that could work..just do some body work
Old Mar 18, 2013 | 04:18 PM
  #435
PepperE500's Avatar
2003 W211 E500
Lol no, this is for my wife so it will be getting smaller lips & barrels.
Old Mar 18, 2013 | 08:42 PM
  #436
W211
i have no idea lol... i ran into problems with that when i was trying to run spacers though
how much poke do you have? depending on low you go the front is def not going to fit... i'm at 9.5 +10 up front and i'm pretty flush but i also gained just under an inch on each with those fenders i had made... and you still have 14mm on me that about another half an inch.. i think the rears you will be ok
Old Mar 19, 2013 | 11:38 AM
  #437
09W211's Avatar
those rears could work..mine stuck out a looooot more. but then again, i did take off about 10mm off the backpad and pulled/cut fenders.
PIC REQUEST: w211's slammed or lowered :)-2012-09-16_20-06-41_958.jpgPIC REQUEST: w211's slammed or lowered :)-2012-09-16_20-09-08_309.jpg
Old Mar 19, 2013 | 11:45 AM
  #438
PepperE500's Avatar
2003 W211 E500
I need to re-test fit the rear again since I lowered it.
Old Mar 19, 2013 | 01:55 PM
  #439
ulovemybenzo's Avatar
99 W210 E55
PIC REQUEST: w211's slammed or lowered :)-img_20130318_142634_zpsa27366b3.jpg
Old Mar 19, 2013 | 04:41 PM
  #440
09W211's Avatar
baus. time to get some spacers at the very least.
Old Mar 19, 2013 | 09:05 PM
  #441
FromM3toE55's Avatar
2003 E55 AMG
dayum!
Old Mar 21, 2013 | 09:00 PM
  #442
Okie-1's Avatar
2009 E
Originally Posted by Critter
http://youtu.be/S-BGIcRBPHM
Hellaflush cartoon
I could not resist
Old Mar 23, 2013 | 05:50 PM
  #443
PepperE500's Avatar
2003 W211 E500
Getting closer...
Old Mar 23, 2013 | 09:11 PM
  #444
2014 BMW M235i
When I get back from Ecuador (in an Internet Cafe in rural Riobamba right now) I will be going up to MB of Westminster FINALLY after a long time to get the car lowered. Not slammed but just lowered so there is no wheel gap (but no tuck) if that makes sense.
Old Apr 2, 2013 | 12:51 AM
  #445
99 W210 E55
http://s618.photobucket.com/user/min...ceced.mp4.html
Old Apr 2, 2013 | 04:56 AM
  #446
2014 BMW M235i
Awesome! That's the system from AccuAir, right?
Old Apr 2, 2013 | 12:15 PM
  #447
99 W210 E55
bags are from universal air, 2 viar compressors, 5 gallon tank, and autopilot v2 air management system from airlift
Old Apr 2, 2013 | 02:41 PM
  #448
GunMoto's Avatar
EG8 | E46 | W211
OMG...legit!
5x114 with wobble bolts?
Getting closer...
IMG]https://lh5.googleusercontent.com/-oUCVYzXpQeU/UU4jArinwqI/AAAAAAAAGI0/f1P6XppEmJY/s1095/IMG_00552.jpg[/IMG]
IMG]https://lh4.googleusercontent.com/-GUh5DSLRggs/UU4i8TuHVyI/AAAAAAAAGIc/i1pj0ixKzI4/s821/IMG_00549.jpg[/IMG]
IMG]https://lh6.googleusercontent.com/-pSxLhur5r1g/UU4i_Neqg2I/AAAAAAAAGIs/cJ5jRCu_5Do/s1095/IMG_00551.jpg[/IMG]
Old Apr 4, 2013 | 01:11 PM
  #449
09W211's Avatar
probably. either that or re-drilled
Old Apr 5, 2013 | 12:43 PM
  #450
Scratchyhalo1's Avatar
08 BENZ E350
Attached Thumbnails PIC REQUEST: w211's slammed or lowered :)-image.jpg
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
