TIRE SIZE HELP: Going to 19"s
9.5 up front might be too wide. 8.5-9 is a standard front width on the W211. 30mm is fine.
2007 E350
W211 Elegance Saloon
2007 E350
2007 E350
#33
I run a 265 tire "stretched" on a 10.5 rim. stretching the tire makes the sidewall rounder, meaning less chance of rubbing. I also run Toyo, which has a rounded sidewall and runs narrower than other brands.
you're running a 245 on a 8.5 rim, which means the tire doesn't stretch. It will sit very square. for reference, on my smart car, I tried yoko's. A 195 Yoko is just as wide as a 215 Hankook.
![](http://i203.photobucket.com/albums/aa205/terrylau828/DSCF0032.jpg)
![](http://i203.photobucket.com/albums/aa205/terrylau828/DSCF0033.jpg)
kevstaarr (07-25-2020)
#34
Greetings
This is my first post here. I have a E350 and i'm about to get a set of 19" HRE P107 wheels. I'm not sure about the tires though. If i keep the stock ET and go for 8.5 on front and 9.5 on rear, will 255/35/19 and 275/30/19 clear? How about 255/40/19 and 255/35/19?
Thanks.
Thanks.
#35
2003 e500
whats up guys? new to having an account on any forum but loved this MBWorld due too what I keep reading. but im here now with a question ill like someone to help with.i have a 2003 e500. I wanna put some 19s on her. what tire size would be recommended. the factory is 245/45/17. please and thank you.
Logged in from the Virgin Island.
#36
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
FWIW, I'm running 19x8.5 ET34 front and 19x9.5 ET35 rear wheels with 245/35-19 and 275/30-19 tires on my E63. I'm lowered quite a bit and don't have any issues with rubbing. There's a pic in my sig.
#37
Tire for rim help
It's a 2003 benz e500 stock height as of now but I'll be buying the lowering links but won't be much of a drop I want and the rim is front 19x8 back 19x9. And the back will be staggered. Ps I would even like to put some sort of spacer at the back only. Can u recommend a good size to use. First time dealing with rims.
