TIRE SIZE HELP: Going to 19"s
2007 E350
OK, my E350 is getting lowered this weekend and I want to add tires and wheels next month. I found a set of 19" wheels that I like. The fronts are 19x8.5 and the rears are 19x9.5. I also found a deal on 245/35/19 Yokohamas. How will the same size tires look front and back on the two different width rims.
Thanks for the help!
1 Post
E500 2002. Supra TT 97, Supra NA-T 94, Glanza 96, Starlet 90
dont think you will notice it really. only you will as you will know where to look but i would say try stage it a little anyways lke 235 front and 245 or 255 rear.
I got 235/35/19 and 285/30/19....I was going to put 275 in the rear but got a better deal on 285 pirelli's....people say 285 looks too drastic on w211, but it looks bad *** from the rear and sits flush with the car
Here is the link to see the difference and look :
http://www.bigcustomwheels.com/info_specs.jsp
2007 E63, ML350
2007 E350
2007 E350
I will be running a mild stretch setup on my new rims in order to get a more aggressive setup. my new rims will be 10.5" rears with 255 or 265 tires. Normal width on a 10.5 is a 285 or 295. My fronts will be 9" wide with a 235 tire. Normal is 245.
2007 E350
Hey Tbone, I see you're in the Bay Area too. Are there any "meets" for modded MBZ owners? I do hot rod car shows for a living and know about all of them, but I' like to hang out with some euro guys to swap ideas. Thanks!
There's actually a thread coordinating the site of the next ncal meetup
http://www.mymbonline.com/forum/view...a9839d575f119f
2007 E350
It looks like I'm going with a staggered setup with the same size tire all around. Front= 19x8.5 with 254/35/19 Rear=19x9.5 with 245/35/19
I'm a cheapskate and the Yokohama AVS ES100s on sale only come in one 19" size. Check them out on Tirerack.com. They're only $89 each!!! If I hate them I can always change them down the road.
Also, make sure you are OK with a stretched look. it's not for everyone. Here's a thread with different variations of stretch, from mild stretch to extreme.
http://g35driver.com/forums/picture-...em-up-486.html
A good pic of a stretched tire is in post #7284, picture #8. I would say that's a mild stretch
2007 E350
OK, another question. Would I be able to go with the 19x9.5s all around? Would they work on the front? The offset is 32mm.
If not the 9.5s, how about all 8.5s with 30mm offset??
All four tires are 245/35/19
Thanks!
Thanks!
