E63 AMG body kit Replica?
http://www.bodykits.com/Sarona/Body-...055_KT/710304/
MB-055-KT
Made with enhanced micro-weaved Grade A hand-laid fiberglass. The micro-weave structure provides maximum stability and flexibility to the fiberglass allowing for a custom fitment.
Made to order, ships unpainted and may require some modifications and/or drilling.
I would look for a used kit before I would buy a replica kit that requires hacking to make it fit
Good Luck on your search
Do what Mark says and stick with OEM. You'll be waaaay better off.
And what about the grilles, inserts, foglamps, wires, foam, mounting screws, etc. They just do not give any information on what comes with the kit at all. The bumper covers and side skirts can be found at a junk yard if you look hard enough and be patient (I got a rear door shell for my W211 for $150.00), that will give you OEM quality at reasonable prices (maybe even less than $1500), you still have to paint, fit and get the required accessories to complete the package.
The posts above clearly tell you what you need to know.
Cheers.
