E-Class (W211) 2003-2009
2004 E320 headlight (low beam) replacement
Old Dec 26, 2009 | 01:09 AM
eusnaur's Avatar
mercedes e320
Hello,
I have e320 2004 model, and my car headlights ( low beam) on the drivers side got burned out, don't find a way to replace it, seems very difficult, any guidance or direction in replacing the same is highly appreciated ! I believe the bulb is halogen type.
eusnaur
Old Dec 26, 2009 | 04:40 AM
jimbo1mcm's Avatar
All Diesel Fleet !1983 240d stick,2005 E320 CDI Midnight blue, 2005 E320 CDI, Desert Silver, Kubota
low beams
Did you do a search of this or other forums? The answer is there.
Old Dec 27, 2009 | 12:12 PM
mcleantmw's Avatar
2003 E500 Benz & 2015 BMW M235ix
It's best to remove the coolant reservoir to get better access the headlight assembly on the left driver's side of the engine compartment. It's held in place with only one screw with nut which, if not careful, can drop into the engine compartment when you undo it. You don't have to disconnect the coolant line to the reservoir unit.............just move it to the side a little so you can get your hand down into the headlight bulb area.
