E-Class (W211) 2003-2009
Help, How to put window back on track
Old Jan 5, 2010 | 12:01 AM
bhuang1103's Avatar
BMW528i 2000, Mercedes E320 SE 2002
The passenger rear window fell off its track. Is there a procedure to repair and adjust? All help will be greatly appreciated.
I know the first thing to do is to disable the airbag. Other than disconnecting the negative battery terminal, are there other precautions I should be aware of?
Best regards,
Ben Huang
2002 E320
Old Jan 5, 2010 | 02:45 PM
Clinton Horn's Avatar
2003 E320
It needs a "regulator". A device that pushes the window up and down. I don't know what the W211 part looks like but some resemble a coat hangar. You will have to remove the door card. Motor may or may not need replacing as well. I think this is a semi- common problem on these cars and usually it is the rear. Probably $150 to $200 for parts?
