E-Class (W211) 2003-2009
intermitent problem
Old Jan 12, 2010 | 01:22 PM
CokersE500's Avatar
2003 E500
intermitent problem
Occasionally, my 2003 E500 will not respond if i romp the gas. After it does that, I have to power the car off to reset something so that it will even respond at all. No check engine light gets triggered either.
Thoughts?
James
Old Jan 13, 2010 | 08:16 AM
CokersE500's Avatar
2003 E500
no one?
Old Jan 13, 2010 | 08:25 AM
RobertG's Avatar
things with and without wheels
When you say that it doesnt respond, does that mean that it has no power or the engine does not rev up at all?
Old Jan 13, 2010 | 08:27 AM
Diesel Benz's Avatar
MAF? In your case it may not help reading codes but Star could have some stored codes that do not trigger check engine light. Or does the engine die completely?
Old Jan 13, 2010 | 09:17 AM
CokersE500's Avatar
2003 E500
Gas pedal becomes inoperative. No throttle response whatsoever. Have to coast to the side and restart the car.
Old Jan 13, 2010 | 09:18 AM
CokersE500's Avatar
2003 E500
Engine does not die. Merely no throttle response.
Old Jan 13, 2010 | 10:32 AM
Clinton Horn's Avatar
2003 E320
I believe the W211 uses a "wire" throttle. It may be that an error code is stored somewhere.
I have often wondered how that system fails safe( ie does not go WOT under malfunction.) I have two cars with wire throttle and neither have given a minutes trouble and I cannot discern any difference in "feel" from the old mechanical system.
Since this system could cause a major mishap, I would assume it is foolproof but in your case, maybe not
Old Jan 13, 2010 | 12:15 PM
RobertG's Avatar
My guess is the TPS sensor is bad.
Old Jan 13, 2010 | 12:43 PM
konigstiger's Avatar
'71 Pinto
Inspect sensor contacts (490 & 600 in diagram) behind pedal if fine have dealer, independent, or anyone with SDS check for stored fault code(s) may need to replace accelerator pedal part #2113000904 (for comparison shopping, parts.com $166.75) sensor could be malfunctioning.
File Type: pdf
Old Jan 14, 2010 | 11:13 PM
Ser05E500's Avatar
05 E500
I praise you for your effort(Konigstiger) to help fellow members...you are awesome!
Old Jan 20, 2010 | 09:27 AM
CokersE500's Avatar
2003 E500
Am going to look into this, thank you for the help guys.
Old Jan 20, 2010 | 12:20 PM
vettdvr's Avatar
03 E500 and Corvette
Me Too! helped me more than once. Gracious Thank you to Konigstiger!
