E-Class (W211) 2003-2009
Keyless Go Problem
Old Jan 14, 2010 | 05:49 PM
MBE550's Avatar
2014 E350, 2015 ML350, 2017 X5
Keyless Go Problem
I searched but couldn't find same problem.
One of my key fob stopped working for keyless door lock/unlock.
It still works if I press buttons on the fob. It even works for starting the car without putting it in the ignition.
With the other key, everything works perfect.
I changed the battery in the problem one, but still same problem.
This makes no sense.
The battery in the fob and the car is good and the sensor in the door handle is good. And it is sending out signal since starting the car works. So what else could it be?
Is there a way to resync or reprogram?
Old Jan 14, 2010 | 05:57 PM
malahhaor's Avatar
06 Carrera4
there are multiple sensors in the keyfob, one of them went bad. I have the opposite with one of mine, it will open everything but won't start the car
Old Jan 14, 2010 | 06:20 PM
MBE550's Avatar
Thanks for the info. I guess another visit to the dealer.
Old Jan 15, 2010 | 01:31 AM
Diesel Benz's Avatar
I'm not sure which parts you would call sensors but your problem sounds like the power coil soldering issue, or the IR led (less likely). Did you ever open your keyfob to have a visual check?
Old Jan 15, 2010 | 01:36 AM
Can you explain how do you conclude the handle in the car being OK if you cannot unlock that door without using the remote buttons? You mean the driver's door opens normally with your other key? This does not sum up.
It could be the handle but then the other key should not work at that door. If it was your KG key issue, it would not work inside the car allowing the car to be started either (except when the key is put into the ignition slot). Perhaps some issues were intermittent and you concluded wrong, can you recheck (or explain the issue again).
Old Jan 15, 2010 | 09:36 AM
MBE550's Avatar
I have 2 keys.
With one key EVERYTHINGS works. (all 4 doors)
With the other one everything except keyless door works( all 4 doors)
Old Jan 15, 2010 | 10:58 AM
I have 2 keys.
All I can say is "weird". Let us know what it was when you get it fixed. I cannot think of a coding issue where the other key would be unknown for KG.
Old Jan 15, 2010 | 12:13 PM
MBE550's Avatar
I called one dealer, and they said the key fob is not covered under original MB warranty.
It's not like the key is physically damaged but malfunction in the electronics.
I'm going to drive to the dealer and find out what the deal is.
Old Jan 15, 2010 | 12:16 PM
MB211's Avatar
2005 E500, 2011 ML350
Key is covered under factory warr and ELW and most aftermarket warr. See a better SA that knows what he is talking about.
The key is NOT covered for cracked/split buttons or water intrusion or any type of physical damage......
Old Jan 15, 2010 | 02:41 PM
MBE550's Avatar
Does anyone know if a dealer gets profit from warranty work?
I visited another dealer just earlier, and completely wasted my time.
It seems to me they just want to give you run around until you get tired and give up on these non major warranty works.
They even tried to argue that only one key supposed to work for what they call "Convenience feature" such as keyless entry and keyless go.
I told them both keys have been working and one stopped working for keyless entry. Keyless go still works on the problem one.
They don't seem to believe me, and insisted that the problem is with the car which will require about 4 hrs of diagnostic.
Is it easy to program the key if you buy the new one from the dealer?
If that's the case I'll just get one myself.
Old Jan 15, 2010 | 05:17 PM
konigstiger's Avatar
'71 Pinto
Request to speak with the shop foreman, have him duplicate the malfunction then request a programmed replacement key part #2097660606 under warranty.
