E-Class (W211) 2003-2009
Battery dead after less than week
Old Feb 14, 2010 | 09:25 PM
cgs2008's Avatar
2008 E350 Sport, 2006 GTO, 2007 Honda Ridgeline
I have a 2008 E350 Sport and if the car is not drove in 5-6 days the battery is dead. Seems quite a bit early for a battery to not hold a charge at least a couple weeks. I have a 2006 Pontiac GTO and it has sat idle for a couple months and started right up. I shouldn't have to disconnect the battery if I fly out of town for a week. Any ideas?
Old Feb 15, 2010 | 09:40 AM
vettdvr's Avatar
03 E500 and Corvette
Check your total system. I have left mine at the airport for 2 weeks and started right up.
Old Feb 15, 2010 | 11:58 AM
konigstiger's Avatar
'71 Pinto
Any ideas?
Mention DTB S-B-54.10/162 and have SA note you want them to check at the fuses to pinpoint closed circuit system responsible for voltage drop. This will identify draw (i.e.: malfunctioning control module) and should expedite your repair.
Old Feb 15, 2010 | 08:52 PM
cgs2008's Avatar
Battery
Thanks for the information, it should be helpful. It has happened a few times and I just charge the battery and it is fine as long as you drive it within 4-5 days. Last time I took it in for service, they said battery was fine. But they didn't check the fore mentioned. Thanks again.
Old Feb 16, 2010 | 05:59 AM
aintez's Avatar
E500 2002. Supra TT 97, Supra NA-T 94, Glanza 96, Starlet 90
sounds like either you have something draining your battery over night etc like a alarm or amp that is not switching off etc. Also could be your alternator.
