Easiest way to get a sample of transmission fluid
I'm considering putting a small hose down the dipstick tube and using my hand vacuum pump to suck some out. I don't know of any other way or even if there is one. If someone knows a better way, please let me know.
Duct Tape
I thought I had the part number for the cap lock saved, but couldn't find it... finally found it in a thread started by you, Clinton Horn. The pump i have has a collection jar before the pump so only air flows through it. Over the years I've used it to extract all sorts of fluids, so contamination of fluid in the jar is a concern. I think I'm going to just use the pump to get fluid into the hose and then siphon it into the sample container.
