Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes Benz E Class Why is My Suspension Bouncy?
Guide to diagnose trouble and recommended solutions
Suspension seems bouncy - Airmatic
E500 Wagon 2005 & Porsche 996 2001
Have an 05 E500 wagon 4matic with airmatic suspension. This winter, after driving snow covered roads, the car seems to be bouncy, even on sport 2 setting. Do I need new shocks, or struts? No warning lights have come on, and the tires are in good shape including the pressures. I read through the threads and saw an aftermarket part profiled, is that what I need to replace? Thanks.
With no red lights on the dash, I would not worry about it.
If the system looses pressure and/or clearance you will probably see bright red messages right in front of you.
Perhaps the cold temps did something to the "bouncy" feeling, but normally cold should make things stiffer..
I would not expect any warning lights from broken shocks. It could well be that a worn out part failed when stressed at cold. I'd have the suspension checked.
The air springs would fire a fault message, but you would usually see it from outside too if those had an issue.
I did not consider breakage or plain damage, although low height sensors would probably pick up regardless of cause if the bounce is enough down?
1 Post
E500 2002. Supra TT 97, Supra NA-T 94, Glanza 96, Starlet 90
nope, shocks on the rear are seperate to the airbag unit (unlike the front) so no if the shock goes the ecu wont be able to tell i wouldnt think.
You could have the car lowered via SDS. The more you lower a car with airmatic, the firmer the suspension gets.
Thanks for the feedback.
In other posts, one was directed to Arnott Industries to purchase rebuild air suspension shock assemblies, are these the shocks I would need in case mine were shot? Or can I use standard shocks?
Second, can I get a recommendation on this site for a place to go for repair other than the stealer?
Thanks. Jeff
http://www.arnottindustries.com/part...18_pid133.html
Thanks. Jeff
1 Post
yup you could just go spend the money but wouldnt you want to check if you really need to first ?
I have not heard of any other place that sells them, i have heard of an airbag repair kit, more of a search will reveal that though.
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
Thanks. Jeff
Thanks. Jeff
This stuff has been covered a zillion times on these forums. Do a search and you'll get all sorts of info.
You'll get a recommendation for Indy shops if you just list where you are located....
