E-Class (W211) 2003-2009
Missing Manual Trunk Release Switch
Old Mar 22, 2010 | 12:34 PM
LOVEMYBS's Avatar
10 Cayenne GTS, 07 Porsche 911 Turbo
Both my 07 SL and 08 CLK have exterior manual trunk release latches. My 07 E550 does not. All cars have keyless locks. The only way I can open my trunk is with the manual key, inside trunk release or key FOB. I do not have an auto closing trunk. My MB SA was shocked by this when I pointed it out. Is this normal?
Old Mar 22, 2010 | 02:12 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
Maybe I'm misunderstanding, but can't you just use the trunk latch and open it?
(as long as the car itself is unlocked, just open the trunk with your hand and the latch...)
Old Mar 22, 2010 | 03:57 PM
Diesel Benz's Avatar
Right, I'm shocked about the SA. If the latch is really missing, can you (the OP) confirm the car has been yours from new and the latch has not been removed?
Old Mar 22, 2010 | 04:26 PM
LOVEMYBS's Avatar
You are correct.
Old Mar 22, 2010 | 04:32 PM
LOVEMYBS's Avatar
The latch that I would normally press is missing.
Old Mar 22, 2010 | 07:27 PM
MB211's Avatar
2005 E500, 2011 ML350
What do you mean by press? Should be a handle you "pull" above the licence plate in-between the lights?
So you are saying you just turn the manual key and it opens?
Old Mar 24, 2010 | 08:09 AM
LOVEMYBS's Avatar
Yes, I agree but there is nothing there. I'm returning to the dealer to ask why.
Old Mar 24, 2010 | 08:50 AM
Blk04cobra1's Avatar
2002 S430, 2004 Cobra, 2004 Tahoe
So what you are saying is that there is no "trigger" switch to squeeze in the middle of the trunk? That's really odd. Maybe it broke off somehow?
Old Mar 24, 2010 | 12:47 PM
LOVEMYBS's Avatar
Nothing there to press, pull, lift, squeeze etc. I'm at the dealer tomorrow to get my my two rear O2 sensors replaced (39K miles) and I'm going to ask them about this too.
Old Mar 24, 2010 | 12:57 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Any chance you could provide a pic so that members can help you better?
Old Mar 25, 2010 | 03:08 AM
I read this as "so that members believe you and don't assume you were expecting the old-fashioned push-button at the trunk".
If the trunk release handle is really missing, someone has had to be "working" with the car and leaving parts out that should be there.
Old Mar 25, 2010 | 07:04 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Not necessarily DB. A pic is worth 1000 words and will make assistance easier - failed, missing components, etc
