E-Class (W211) 2003-2009
w211 wheel fitment
Old Apr 1, 2010 | 02:20 AM
thongvilay's Avatar
2001 CLK55
w211 wheel fitment
2003 e500. Do I have to get a set of staggered rims? What offset will work with out having to get spacers? I'm looking for a set of 20's and the ones I like come in non staggered and are 35, 20 and 15 offset....
Old Apr 1, 2010 | 11:54 AM
tbone's Avatar
E500 Sport
Non-staggered is OK. get the +35's. You can run a +20 up front if you want to run stretch tires. But +35 is safe front and rear
Old Apr 1, 2010 | 01:43 PM
sunny_j's Avatar
09 E320 Bluetec
im running 20s with offsets 32front and 42rear. no rubbing even when car is full.
Old Apr 1, 2010 | 04:29 PM
thongvilay's Avatar
2001 CLK55
so what if I do find a set that are only 20 offsets, do I need a spacer for the rears of about 15mm?
Old Apr 1, 2010 | 04:32 PM
Neoii's Avatar
e500
No. +20 is more aggressive to the fender than +35. Spacers would make it worse.
Old Apr 1, 2010 | 04:34 PM
thongvilay's Avatar
2001 CLK55
ooh ok, so it's the opposite then?
So 20's 5x112 +35 should work fine for my car then right? Any recommended tire sizing? 245/30/20?
Old Apr 1, 2010 | 05:52 PM
Neoii's Avatar
e500
245/30/20 should be fine. Just in case, how wide are the rims? x8? x8.5? x9?
Old Apr 1, 2010 | 07:48 PM
thongvilay's Avatar
2001 CLK55
I would probably get 8.5 or if I go with 9's then I would still keep the 245 tire so they would stretch a little bit.
Old Apr 1, 2010 | 08:23 PM
thongvilay's Avatar
2001 CLK55
Something like these, not sure if I want something with a lip. What do you guys think? Will these look good?
Old Apr 1, 2010 | 08:30 PM
thongvilay's Avatar
2001 CLK55
Well what are the tire sizes you guys running on your 20's? sidewall height I mean, I don't want to throw off my speedo by putting the incorrect tire size.
Old Apr 1, 2010 | 11:07 PM
tbone's Avatar
E500 Sport
245/30 is standard for a 20" tire. If you run the +20 on the front rim, you'll need a 235/30
