MB Engine Oil Spec Article
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
Found this article in the April issue of Lubes & Greases -- it's an interesting read if you enjoy this sort of subject.
Regards,
paul...
Regards,
paul...
1 Post
2014 Mercedes C250 Coupe, 1998 SL 600 sport
Thank you for posting that. Quite interesting. I am "shocked" at how much empahsis is on environmental concerns rather then Longevity and performance.
On that note I noticed that the last time I got an oil change they used "Synpower 5W40" I thought that Mobile 1 0W40 was the only approved oil?
RickP
RickP
RickP
RickP
Don't be shocked --- the priority order is for cars nowadays is 1) reducing emissions, 2) increasing fuel economy, and 3) Performance (quality, etc).
Obviously, all three of these engineering requirements cannot be met simultaneously, so guess which one is going to suffer.
Check out this site: http://bevo.mercedes-benz.com/bevoli...ets-sort1.html for oil recommendations depending on which spec is called out in your manual (229.1, 229.3, 229.31, 229.5, 229.51).
Regards,
paul...
03 E500 and Corvette
Rick,
Regards,
paul...
Regards,
paul...
Auto makers decided that even with the shorter engine life on new lubricants that the higher "CAFE" would allow more profits through sales of more expensive cars. So engine life would suffer and to quote one car maker, "it is good enough to get the engine through the warranty period".
So it is really important to use the correct lubricants in cars today. Thanks for the update. Miss L&G since retiring. vettdvr
04 E500
vettedvr,
If you go to http://www.lngpublishing.com/LNGmagazine/index.cfm and click on "Current Issue/Archive," you may be able to catch up with whatever you've missed since December 2004. I don't know what it takes to be a qualified subscriber to the digital edition, but at least for now I appear to be one of them, so most likely you are, too.
Dan
Dan
http://bevo.mercedes-benz.com/d/d/en/Spec_224_1.pdf
Basically, use fully synthetic (Mobile 1 - there are others). In the southern part of the US, make sure that a 40 0r 50 weight oil is used. A 20W-50 is acceptable by MB.
In Northern climes, Canada, Northern US a 5W-40 or 5W-50 meets MB specs. See link above
Viscosity
My comments pertain to gasoline engines only. Sorry I was not more specific. The W in the 10W-40 refers to Winter. In warmer parts of the world, there is therefore no need for operating the engines in the cold temperatures referred to in the chart that is found in the link.
Where I live the temperature variations are from a -30F to 100F therefore the multiviscosity oil with a wide range is an absolute necissity.
RickP
RickP
There's a long list of approved oils: http://www.startekinfo.com/StarTek/o...stedDocId=9511
Might want to read: http://papers.sae.org/2007-01-4133/ to get an idea just where motor oil technology now is in the 21st century.
