E-Class (W211) 2003-2009
Old Jun 10, 2015, 12:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Exterior Guides
Print Wikipost
Power windows problem
Old Apr 2, 2010 | 10:32 AM
masterross's Avatar
w211 '04 Avangarde
Hi guys,
I have a problem.
The power windows stopped warning me when I leave some of them open and cannot be closed from the remote key anymore.
I've tried to resync them:
Move respective window to upper stop
and hold power window switch depressed for
approx. 1 s.
But nothing changed.
The sliding roof works ok.
Any ideas?
Thanks!
Old Apr 4, 2010 | 12:18 PM
masterross's Avatar
w211 '04 Avangarde
No one?
Maybe some one knows where is the windows fuse?
Old Apr 4, 2010 | 03:14 PM
vettdvr's Avatar
03 E500 and Corvette
Originally Posted by masterross
Hi guys,
I have a problem.
Any ideas?
Thanks!
So does this mean you really Can close them from the door switch, but not th ekey fob? Or does this mean the windows sometimes don't close at all with the inside switch.
Problem statement:??
Old Apr 4, 2010 | 03:27 PM
masterross's Avatar
w211 '04 Avangarde
The problem starts few months ago when my battery was discharged.
After that I read that power windows should be re-sync.
I did it and they worked ok but forgot about sliding roof.
Few weeks later I realized that sliding roof auto open/closed not works.
So I removed it's fuse and re-sync as described.
I didnt test windows couse they were ok.
But now I found that they are not sync.
Means all work from the doors buttons but if I leave some window open I dont get warning message and I cant closed it from remote key or outside door button (I have Keyless-Go).
So I need somehow to reset windows again but I dont want to disconnect battery.
So any ideas will bee appreciated!
Old Apr 4, 2010 | 04:46 PM
BavarianPride's Avatar
2013 E350
I dont know if you did or not, but once sync is lost, you need to re-sync ALL windows and your sun roof again.( open each window seperately all the way down, hold 3 sec. all the way up, hold 3 sec. + sunroof ) give it a try......
T.
