E-Class (W211) 2003-2009
Help: 2007 E63 starts off 2nd gear in S mode
Old Apr 20, 2010 | 12:23 AM
box986's Avatar
W211 E63
Read on the forum that a simple SW update will make my early production model E63 to start off 1st gear in S mode as it should. Problem is my car is now in Taiwan and the dealers here and MB-Taiwan does not want to do it until they can confirm it will be a fix.
Can someone provide me with a TSB or some sort of internal reference number for the procedure? thank you very much
Old Apr 20, 2010 | 12:55 AM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
I'm sure Konigstiger will pop in here pretty soon and give you the correct TSB.
Edmunds.com does list TSBs on their website here: http://www.edmunds.com/maintenance/r...erviceType=#14
Don't know how accurate it is.....
fwiw, here are two TSBs about the 2007 W211 with the 722.9 tranny:
Component Description:
45. POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Number: 2007010008
Bulletin Date: Feb 2007
Vehicle: 2007 Mercedes-Benz E-Class
Summary:
CHECK TRANSMISSION CONTROL MODULE SOFTWARE AND UPDATE IF NECESSARY (722.9 TRANSMISSION); UPDATE ENGINE CONTROL MODULE SOFTWARE AS REQUIRED. ( NHTSA ITEM NUMBER - 10021381 )
_______________________
14. POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Number: SB-200812000
Bulletin Date: Dec 2008
Summary:
MERCEDES BENZ: MODELS 203, 209, 211, 219,230, AND 463; MODEL YEARS 2005-2007. REPLACE PILOT BUSHING AT ELECTROHYDRAULIC UNIT. DAIMLER AG HAS DETERMINED THAT ON AFFECTED VEHICLES THE TRANSMISSION PILOT BUSHING MAY LEAK. DEALER WILL REPLACE ( NHTSA ITEM NUMBER - 10030904 )
Old Apr 22, 2010 | 11:04 PM
box986's Avatar
W211 E63
After 3 emails to MBUSA regarding my S mode not starting in 1st gear problem here is the reply that I got from them:
We researched your inquiry. It always will start from 2nd gear in C
mode. In S mode it will most of the time but that depends upon driving
conditions. Yes, the vehicle is operating as designed. Additionally, we have been advised there is no bulletin on his question .
I simply wanted a procedure number for my local dealer in Taiwan to perform the job and not debating what its suppose to do. Can anyone help!
