Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes Benz E Class Brake Modifications
Overview of popular modifications to customize your Mercedes-Benz
W211 AMG BRAKE UPGRADE
#54
S211 E350 wagon, w211 e550, 2023 glb250, 2013 Audi q7
#56
Where are you located? We could see if we work together on this one...I'm thinking that the sl63 or if you look on eBay and check out the g63 brake there selling,those brackets might work for us because of the shape as the made for 390mm rotors but look diff. Then other 390mm brackets. Reason is I think our tie rod might touch...
#58
you bring up a good point... I'll have the car on a lift again this weekend so I'll peek underneath to see what could get in the way. I'm in Kansas City, how about you? I'll look at the G63 brakes and see. thanks man!
#59
I'm in Virginia so that won't work. But since your gonna look I'm pretty sure the non 4matics tie rod is on the Foward side as ours are on the same side as the calipers. I posted a picture in one of the treads maybe even this one of the tie rod...
#60
DONE!!!! WILL BE STARTING GROUP BUY
Ok guys I been talking with racingBrake about fabricating adapters for our 4matic cars. There on the board and sell BBK stuff and 2 piece rotors. So they have done it. We can get the whole front or minus calipers. But considering the had to fabricate these adapters they do want to sell the two-piece rotors/pads with t
he adapters as a set.
Here's the GroupBut thread I started for details https://mbworld.org/forums/suspension-braking/612726-w211-4matic-amg-brake-group-buy.html
#64
#65
#66
We have put together an AMG BRAKE kit for W211 Sedan or wagon. The complete set we have including:
AMG E55 8 piston front calipers
AMG E55 360mm rotors + pads
AMG E63 4 piston rear calipers
AMG E63 340mm rotors + pads
The E63 rear caliper has better cosmetic appearance
All brand new OEM AMG product from local Mercedes dealer!
Contact us when you need W211 brake upgrade!!
AMG 8 piston front caliper
Rear E63 4 piston caliper + rotor
Complete AMG brake kit installed!
Still can not see the BBK? We can also help with caliper paint job
#73
2011 e350 amg
hi there,
i want to upgrade the brake system of my merc to amg 6 n 4 piston caliper. as you have already replaced in earlier, wanted to know if the amg calipers are a straight fit or we will have to make adapters?
i live in UAE, wanted to know the cost of red color amg 6n4 calipers with rotor along with shipping cost.
thank you.
awaiting reply.
nabeel
thank you.
awaiting reply.
nabeel
#74
I have a 2016 W205 C63S that I want to upgrade the rear calipers to 4 pot or maybe 6 pot like the Nissan GTR.
The C63S already has large rotors on the rear (not sure how big) so only wanted to do a calipers swap if possible.
Can you help with this?
#75
C63S Rear has a floating type caliper w/electro-mechanical so the same caliper is used for both stopping and parking, and doesn't have a drum brake so you can't upgrade to fixed type calipers.
The rear rotor is 360mm while the front is 390mm.
