Bi-Xenon Headlight adj ???
Any simple instructions as to how to do this?
Ed
PS: If you remove the wire socket first that plugs into the back of the bulb housing, it will be easier.
This is the H7 I see referred to? What all needs to be replaced ?
Is all I replace that bulb and the fog lamp? If I go to a "White" or "Blueish" fog lamp will it nullify the functionality of the fog lamp as intended?
And yes, replace the HI Beam bulb with the H7 PIAA XtremeWhite and the Park bulb with the 19172 wedge bulb Xtreme White.
The Fog lamp I let alone.
Mark
Ed
Can someone confirm the part number and type for the fog lights? I've changed the side lights for Xtreme whites which look great, just need to do the fog lights now but wanted to check the part number. Thanks!
If you want to change fog light bulbs, you'll have to do what Josseesq recommends above. Mark
All I can tell you is that when d2technik installed my foglight bulbs, they match perfectly with the other bulbs I have installed. MKASSB is right when he said PIAA does not make the H11 bulb, that's why I had to get the bulbs from d2technik.com. The PIAA bulbs I did get are:
H7 (high-beams)
19169 (? I think for the parking lights)--you can look at my previous post on the exact part number.
D2technik charged me only $40 including installation for the H11 bulbs. If I have time I'll take a picture of the front end of my car with all the lights on so everyone can see the color.
I just look in the on-line owners manual, and that says H1 55W. Is that the same thing? I see PIAA list H1 but not H11? I don't want to order the wrong bulbs at that price.
Pull the bulb out and look. I ordered what the manual said, but had to send it back. Mark
Owners manual saids one thing, but the bubl is printed with H11?
I can't find anywhere in the UK that sells an HID look H11, so I'll try d2technik.com and see if they'll ship over here.
I noticed that I had only Xenon in low beam.
After enquiry at MB, it looks that the very first models have only simple Xenon (it was sold as bi-Xenon on evry documentation...).
No retrofit looks possible.
I am waiting a "commercial" solutaion from MB.
You park your car in front of a wall.
You switch the lights from low to high beam.
In my case, you notice celarly that the Xenon remain in low beam whatever you do. But the other conventional lights are perfectly switching on or off.
As I understood it the Xenon lights don't themselves switch to high/low, but a cover that is over the lights when in low beam moves when you switch to high beam.
In France, we cannot say precisely when the car was built.
If I refer to the EU homologation sheet of my car is end Nov 01...
The car was delivered end 04/02 from MB France preliminary stock.
Thats true that the xenon light should be equiped of a kind of shutter.
Do not worry, I seem to be one of the very few affected by this problem.
