Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes-Benz E-Class: Why won't my sunroof open
Guide to diagnose trouble and recommended solutions
Loud clicking sound from panoramic sunroof
#76
Received 4,440 Likes
'71 Pinto
Most common cause warped motor cover, resolve: either motor replacement (link - post 73 above) or makeshift cover replacement (shown on c class / same motor for 211 & 203) https://mbworld.org/forums/c-class-w...ml#post4245982
#78
#79
Hey guy, my 2008 R320 does the same loud clicking noise, opens up but wont close. please email me the instructions: martinv.hr@gmail.com
Thank you very much!
#80
Hello guys, I have the same problem, panoramic roof opens up but wont close with a loud repeat clicking noise.
#81
Same problem here
I have the same issue on a 2006 R350 Pano roof. If someone would be kind enough to send the .pdf on the repair, I'd be grateful.
Paul
pburt@westlakefg.com
Paul
#82
Same problem with my s550
#83
'71 Pinto
Check links above - posts 73 & 76
#85
pano roof problems
I know this thread is old, but if you still have the instructions then please send me a copy as well. My panoramic roof started having the same problems.
nneshkov72@gmail.com
I have 2003 W211 E500
#86
2002 c32 ,2002 c5 zo6
#87
pano roof proble,
New to this web site and I already got some very helpful hints. Now the panoramic sunroof will not operate and makes this very loud clicking sound that seems to be coming from underneath the light pod above the rear view mirror. Anybody have the same issue? Is it a defective motor, track, etc? Does anyone have any idea how to remove the light pod and get to the motor?
I appreciate the help and will post pics when I attempt to fix it.
if anyone can help me
please email me at : saleeba_91@hotmail.com
#88
#90
#91
Panoramic Problems
First there was the clicking noise and the shade wouldn't close, now the roof will not completely close. Right rear sticks up, any information on how to manually close with pdf, or visuals will be greatly appreciate...before I head off to a repair shop. Send info to talentz2southfl@gmail.com
Mercedes E350 2008
Thank you in advance.
Mercedes E350 2008
#92
2002 CL203 C200 Kompressor
MBWorld No Help Desk
I would try the Australian/New Zealand benz site, you are more likely to get a valid response than from this one.
I reckon they are a bunch of dealer-spruikers here, and won't answer anyone's questions unless it suits them! OR, they just don't know the answer.
Do as I am doing, close your account and move on!
#93
E55 AMG
panoramic roof not closing. loud clicking
I assume the motor is bad. Mine is clicking loud and fast and won't shut all the way. Can someone send me the manual link to change it?
#94
pano roof stuck open,
I need the instructions, mine was making the clicking noise, someone opened and now it will not closed. The drivers rear side is up in the back. tried the tool in the dome light, does nothing
#96
How to remove Pano motor
Mine did a similar grinding gear sound. I used the pdf and took it apart to get the motor out, the gear cover had bent just like previously described. Instead of replacing the motor, which technically should bend again, i straightened it to close the gap then took a galvanized junction box cover from Home Depot and cut it out to the shape of the cover. Then JB Welded it onto the outside of the gear cover. Presto! Fixed and will never happen again. $1.29 well spent
Where did you find the PDF on how to get to the motor?
#97
Need instructions to fix Pano roof clicking
I see all the posts on what can be the cause. But nothing on how to deal it.
Could someone email me a TheAlfredo@Gmail.com.
I don't want to get rid of my '04 E500. But can't see myself spending $3000+ to have it fixed.
#98
Help Fix Pano clicking
Help, I refuse to pay to get this fixed. If any could send me the PDF to fix this I would be grateful.
Monica
Monica
#99
I had the same problem with my 2008 E350. The Pano sun roof opened but would not close without pulling it forward while pressing the button. It sounded like gears were grinding. GEARS ARE GRINDING. DON'T TRY TO ACTIVATE THE SUN ROOF IF YOU HEAR THIS NOISE.
OK, Maybe just one more time to get it closed.
I fixed it today. Here's how I did it.
I linked a YouTube video below that shows the Overhead Control Panel removal.
Page 1 of instructions to repair sun roof motor gears.
Page 2 of instructions to repair sun roof motor gears.
#100
ssunroof problems
The popping and clicking ur hearing is the gear on the end of ur sunroof motor .... it's broken they break easy I guess to save other parts u have two options once the motor is removed (easy right behind interior lights) buy a brand new motor with new gear attached or figure out a way to get old broken gear back on shift ....
