E-Class (W211) 2003-2009
What is the easiest was to know if a E350 has BI Xenons from the outside?
Old 06-12-2010, 09:18 PM
genius's Avatar
2003 c240 4matic
Iam looking at a E350 for sale online and have acouple pictures of it.
Is there a way to recognize from the outside if it has BI-Xenon lights?
Is there any way to know if it has the P2 package just by looking at pictures?
Old 06-12-2010, 10:10 PM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
P2 FAQ
Old 06-12-2010, 10:21 PM
genius's Avatar
2003 c240 4matic
Originally Posted by amdeutsch
that doesnt answer my questions with the BS link/dont care link.
Old 06-12-2010, 10:36 PM
Benz-O-Rama's Avatar
If it has Bi-xenon, there will be washer cutouts in the bumper.
Old 06-12-2010, 10:53 PM
genius's Avatar
2003 c240 4matic
thanks for the reply. great help.
Yes in the picture, i do see the cutout for the washers.
But also the the P2 package also includes the push start shiftknob but i see it doesnt have that.
When someone buys a new car with a package,and could they have pick BI-Xenon lights(P2package) and cancel of the shiftknob start(P2)?
Get what iam saying?
thanks
Old 06-13-2010, 12:37 AM
Dema's Avatar
i535
If you are going to buy a car, then better just run VIN against some info system to get complete reports of options the car has. However if you are just walk along with a friends and talking about cars you see on street, then yes, some knowledge of appearance of packages can be helpful
Old 06-13-2010, 06:14 AM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Not 100% true. I've seen an 07 with these washers but no BIX. There was a separate code and $ amount on the sticker for those.
Old 06-13-2010, 02:38 PM
LOVEMYBS's Avatar
10 Cayenne GTS, 07 Porsche 911 Turbo
Keyless and Xenons come with P2, manual starting and HIDs come with P1. Xenons look like a round glass shaft, HIDs are a bulb.
Old 06-13-2010, 04:40 PM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Incorrect. P1 = halogen. BIX = HID in P2. BIX are a bulb as well; same as halogen just different construction and gas.
We love your
Old 06-13-2010, 04:48 PM
Barry45RPM's Avatar
2015 ML 350
Have someone start the car. Have them turn on the headlights & you watch one of the headlights from about 20 feet away.
Halogen will light right up & have a slight gold cast to the light. Xenons will flicker to life (almost like a flourescent bulb) with a blue-ish white-ish light. If they are active bi-xenon lights they will do a littl dance up & down &/or right & left.
Old 06-13-2010, 04:53 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
for 07-09, if it has keylessgo, it has BiXenons. Washers came on the sport package for 07+ cars where unlike before, only with the BiXenons.
Old 06-13-2010, 05:05 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
We love your
+1
HID is simply "high intensity discharge." It's a term for the electric arc that makes the light. And in the auto industry also known as Xenon gas headlamps. Or Bi-Xenon (BIX) if the projector has a shade and makes a cut-off for a high beam and low beam pattern.
There's a bulb in both P1 and P2. One is halogen and burns with a filament (H1, H3, H4, etc.) the other ignites a gas instead (as a metal halide lamp filled with xenon gas) and uses a ballast to provide the current. Xenon gas allows for immediate start-up.
p.s., washers are an ECE regulation with certain intensity lights, and not required in the USA.
Old 06-13-2010, 05:43 PM
genius's Avatar
2003 c240 4matic
Well in the picture i see, on the side of the steering wheel that it has the slot for the key to go in. So it looks like it doesnt have keylessgo.
Right?
Also would it maybe not have the keylessgo and have Xenons. Can you pick what you want from a package when you buy a new E350?
thanks
Old 06-13-2010, 05:46 PM
genius's Avatar
2003 c240 4matic
yaa i know that, but the dealership is 76miles away from my house.
Thats the first thing iam goin to do when i go see the car in a couple days.
thanks
Old 06-13-2010, 05:47 PM
konigstiger's Avatar
Received 4,435 Likes on 3,152 Posts
'71 Pinto
http://www.ragtop.org/mbbrochures/
Old 06-13-2010, 08:37 PM
Cavu's Avatar
Current: 2019 M5 Donnington Gray, 2021 GLE53 Diamond White Met. Previous: 2010 C63, 2012 E550 Coupe
Right?
The Keyless Go cars still have the slot for the key. You need to see a pic of the transmission shifter to see if it says Engine Start/Stop. If not, then no Keyless Go.
Old 06-14-2010, 12:10 PM
Long Islander's Avatar
2018 E400 4matic Wagon
Right?
Even if you have Keyless Go, you still get a slot for the key and you can start it in the usual way. I like this feature because it gives me a place to put the key on a long trip, instead of in my pocket.
Old 06-14-2010, 04:47 PM
genius's Avatar
2003 c240 4matic
thanks for the info.
How about if you have the key in your pocket, can you still start the car with gear shifter button?
Old 06-14-2010, 05:39 PM
Trey's Avatar
2008 S550 designo
Yes, that is the point of Keyless Go. You can also unlock and lock the car with the exterior door handle with the key in pocket also.
Old 06-14-2010, 08:35 PM
Exactly. Once you get used to Keyless Go, it seems like such a chore to take the remote out of your pocket, press the button on the remote to unlock the doors, put the key in, and turn it to start. With Keyless Go, you just walk up to the car and open the door. While you use your left hand to release the parking brake, your right hand is already on the shifter and pressing the start button. This saves you at least 5 seconds on each entry. Do you know what that adds up to in saved time during the life your your car??? Oh, and not to mention that you don't have to remove your gloves in the winter.
Old 06-14-2010, 10:40 PM
220S's Avatar
You can have the tiny key fob chip and the battery embedded in your wrist by a veterinarian and dispense with having to carry it in your pocket altogether.
Only 4 stitches and it took just 1 week to heal completely.
Old 06-14-2010, 10:52 PM
genius's Avatar
2003 c240 4matic
yaa. but in the picture i dont see the button on the drivers door handle.
Are the buttons for the keyless go on the passanger handles also?
I seen on a differant e350(black color) with the button on the drivers door.
The button was black.
The car iam looking at is Cream/white. Would the buttons on it still be black?
Old 06-14-2010, 10:54 PM
genius's Avatar
2003 c240 4matic
yaa i would love to have that. Did you have any problems yet with the keyless go?
Old 06-14-2010, 11:04 PM
genius's Avatar
2003 c240 4matic
The dealer said that it also has the rear and side blinds?
Is there a separate button for the rear blind to go up and a button for the side blinds?
Where are they located?
i heard the blinds tend to have alot of problems? true?
How does the electric trunk closer work?
Old 06-14-2010, 11:09 PM
220S's Avatar
Rear blind runs remotely with a switch in the front console. Side blinds are completely manual. Electronic trunk close is convenient.
Keyless Go, trunk close, rear sunshade; all can fail whenever they feel like failing. Warranty will cover it. Electronics are the bane of all modern cars, esp MBs.
Quick Reply: What is the easiest was to know if a E350 has BI Xenons from the outside?
