wood steering wheel?
E500, White, Pacfic Blue Int. Sport
Can anyone tell me if the wood steering wheel has a heat funtion when ordered with the E5 pkg?
1 Post
Honda Accord EX V6
Order wood wheel
can we order the wood wheel after we get the car? if we can do we have to pay for installation fee and how much? hope anybody knows and can answer this... thx
E500 Sport
Re: Order wood wheel
2010 Prius & Miata MX5 PRHT, 2010 Toyota Venza AWD, 05 C55 AMG, Yamaha 1100 Custom, Honda 250 Reflex
There are really two separate options for the steering wheel for the W211.
The first is heated and the second is wood/leather.
The heating option must ordered and be fitted at the factory while the wood/leather wheel can be retrofitted later.
If you have ordered the heated wheel option without wood/leather,the wood wheel can later be retrofitted and the leather only rim area will now heat up.
W204 C300
You should get the Brabus steering wheel it is much nicer and bigger. I have it and love it. I like it even more then the S500 wood steering wheel. The Brabus one is like $900.
E500 Sport
The only thing I would caution on Non-OEM Steering Wheels (like Brabus) would be any insurance, warranty and/or Liability issues with the Airbag, etc. items that would have to be moved/changed. Mark
2003 E500
Thanks.
That doesn't sound right to me.
My understanding is the wood/leather wheel is the same, it's just that when you have the heating option they connect it to the wheel and it heats the leather section.
(i.e) the wheel is the same, it's just whether you can plug the heating wire option in or not that activates it.
2003 E500
Confused
Originally posted by mkassab
Your dealer is correct... i.e.,
Heated wheel = Leather only.
Wood Wheel = No Heat, period.
Sorry...... Mark
Sorry...... Mark
However, I found this in an older thread:
Originally posted by clembo
My car has the wood wheel and it is heated. The switch to turn it on is the end cap of the wheel positioning lever on the left of the wheel. Only the leather parts heat up not the wood.
Originally posted by jposhea3
The parts guy called in to MB today and confirmed that there is only wood/leather steering wheel for the W211 E-class.
If you have a regular heated steering wheel, the leather parts of the wood/leather wheel WILL be heated too.
I guess that implies that the wiring is already done on all wood/leather wheels (perhaps on *all* W211 wheels), and it only needs the steering column wiring and switches to put power to the heating coils.
clembo or jposhea3, can you help?
2003 E500
pat a.,
Thanks for the reply.
I assume your wood wheel was installed by the dealer, not the factory. Do you have a part # that I could provide to my dealer?
'03 E320
Leather to Wood Steering Wheel
I have std leather heated steering wheel and wanted to upgrade to wood/leather combo. Went to the dealer, and they had wood/leather wheel in stock. Took it out of box, and there were no wires (none) that would be needed for activating heated portion. We checked parts catalogue further and could not locate a replacement wood/leather wheel that allows heated function to work.
Sounds like to have heated wood/leather wheel this needs to be ordered from factory to have functionality, or find a parts dealer in Europe that can provide more than what MBUSA has to offer.
If anyone locates heated wood/leather combo wheel, please post details.
Briar, you are correct. The dealers do not have a part number for the heated wood leather steering wheel. I got mine because I had ordered the heated seats/wheel package on my car, and complained loudly enough to MBUSA about my inability (at the time in early december 2002) to order the wood wheel option. So MBUSA had my dealer do something called a "WEO", which stands for something like "warantee part order" - i.e., ordering a replacement part for one that failed under warantee. In other words, you have been able at various times to order the wood wheel and heated wheel combination from the factory, but could not order that combo as a dealer installed accessory. But since any part on a new car from the factory MUST be replaceable, the wood and heat steering wheel part can be ordered as a warantee replacement part. That is how I got my precious wheel.
Ridiculous, huh? I swear, if there has been another new car launch that was as badly mangked as the w211, I would be shocked. I would guess that many careers have been ruined....
