Summer vent feature not working
Can't remember the last time I used this feature (and it worked) but now I can't open the windows/roof by holding down the unlock button on the smart key, after unlocking the car.
Tried synchronizing the windows and then the roof, but still not working.
Also won't work via the recirculate and charcoal filter buttons.
However, if I open the windows and roof manually, I can close them via the buttons and or the drivers door outside lock button (keyless go). So the close feature does work.
Any insight to what's going on here would be greatly appreciated.
Apparently not a common problem, as a search of the forums brought up zero.
I'm willing to bet the little IR window in the door handle is at fault. Yeah, I know... if it were broken, the feature wouldn't work in the closing procedure... but this is an MB, and nothing works logically. (Not that it doesn't work as designed...)
). Also you would not accidentally close the windows from distance when a kid or a pet had his/her/its head/leg/arm out from the window.Starbrite, if you did confirm that "one-touch" opening and closing works from the buttons (windows and sunroof), then it is likely the IR sensor at the door that has failed (as explained above). I think this car does not have an IR sensor at the passenger door, cannot test it on the other side then.
I would have suspected the IR sensor in the door, however, the thing you all missed in the OP is that the feature also does not work with the "recirculate" and "charcoal filter" buttons, and it's supposed to.
@Barry, you've had FL weather up here for so long it's like being in both places at once.
) and later on you can make all windows and the sunroof return to the previous position from this button.But if you start with all windows closed, I don't think you would reach the results as from the summer convenience feature.
Unless the manual is wrong, page 197, lower right side, lists all 3 methods to activate summer vent feature.
@tpabenz, I tried a new battery and a different key, with no change.
@ronaldk, no, the door button will only close windows/roof, not open.
Interestingly, I put the key in the ignition and turned to 1st and then 2nd position, then off and removed.
When pressing the unlock button on the key, this time everything worked ! Tried it a 2nd time and no go. Tried the key in the ignition again and this time it didn't work. So my guess is that there is some kind of sync issue.
I searched the entire forum again using several different terms and came across a post in the W220, S Class forum, by 'SKYLAW", titled Handy Resets, that contained this :
Global Synchronization of auto open/unlock (windows open/close when car is unlocked/locked):
"Global synchronization synchs all of your windows and sunroof so that they all open or close by a single command (pointing the key at the IR receiver in the driver's door handle, and pushing & holding lock or unlock). Place the A/C switch on the A/C control panel in Auto, and the recirc button on. Then press the button between the temp controls and hold it until all of the windows and roof close. This should resynch them. After that, the Smart Key should open or close the windows and sunroof as well as lock or unlock the doors.
Also: Door locks are controlled from the key by radio frequency, and will operate regardless of direction the key is pointed. The auto window/sunroof features are infrared, however, and operate only if the key is pointed at the small square IR receiver in the driver's door handle. The IR range is usually less than the RF range, and can be affected by bright sunlight directly on the door handle."
The text in bold is the thing that doesn't seem to apply to the 211. The only button between the temp controls, that I see, is the "O" button and that doesn't work. I'll pm him and ask what that button is.
Edit: apparently doesn't work for the 211
So, grasping for straws now, I thought I'd toggle it back to "unlock all".
Well, just terrific, now that doesn't work either.
I note that the owners manual does provide the methods to reset sunroof and seperately how to synchronise (reset) the windows. All in "Open air" section. Perhaps consider doing this.
In any event, that page is not in my manual, (MY'04) nor does it work.
All it does is open the door (with or without pulling, just grasping the handle)
Syncing the windows and roof was the first thing I did, as mentioned in the op.
I may disconnect the main battery next to see if that will do some kind of "reset"
1. Press and hold the keyless go "close" (outer) button on any of door grips for at least 3 seconds (you will hear the clicking of the locking relay even if the car was already locked).
2. Release the button and within 1 second press and hold (also for approximately 3 seconds) the open (inner) buttom of the same handle. The door will not release, but will unlock the car (depending on your oen door / all door programmed preference) and all windows and roof will be opened halfway (you may be lucky and have full open option in USA?)
I have tested on both our e-classes MY 2004 and MY 2009 and it works on all 4 doors.
Thanks for posting it. (can't find it in my manual)Did it and worked fine on all 4 doors. Windows went down half way.
Tried it with the key and now it works (windows go all the way down here).
With Pano roof the sunshade has to be open for the roof to open, otherwise just the shade opens.
So, a big "Thank You" to you, Ronaldk !!
Edit : BTW, the manual obviously is wrong re the recirculate and filter buttons opening the windows/roof.
They still just close them, and reopen to the same positions.
Edit#2:Well, it looks like the car didn't like sitting overnight, back to not working again.
This is properly explained at the "Air recirculation mode" section. Page 197 should refer to this section (too) instead of referring to an earlier section where the position of the button is explained.
I had thought the IR sensor in the door key tumbler would have to be replaced to get the feature back, but this latest incident seems to point to a programming type issue.... but maybe not. ("Logic 7" is a stereo thing, and too often the only logic I can find in reference to my favorite ride)
Pushing the recirc button does close all windows and sunroof, and then reopen, so I don't think it's a sync issue, but I already tried all the sync options I can find. (I think I synced correctly) So does anyone have some insight? Actual experience? Wild a$$ guess? It would be quite disheartening to spend the time and money for a new IR sensor and not have the issue resolved, or rather annoying to spend the time and money when there was a free fix.
Mine's still not working btw.
Does that sensor control anything else besides the vent feature?
Edit: @hand....did you get the conformal coating at the Shack as well?
