E-Class (W211) 2003-2009
Old 06-10-2015, 12:12 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Brake Guides
Print Wikipost
DIY Front Brake Job 2006 E350
Old 04-19-2011, 11:25 AM
  #51
sentralfyr's Avatar
2015 S205 AMG
Thanks alot for this guide!!
I used it for my 2004 220 cdi, even if the brakes was not the same type, but i have SBC
Old 05-01-2011, 04:48 PM
  #52
Acace1957's Avatar
E500, C230
Terrific post, thank you very much. I'll add a few other things. The caliper bolts are 18mm. For those of you having trouble getting the discs off - hit them from the front with a heavy dead-blow or rubber mallet. The lip that goes over the hub is only about an 1/8" thick so the torque action will break it free. It will save you a lot of headaches and banged fingers. Also, if the soft, chewy centers of the pistons fall (and some will), be very careful picking them up and replacing them - they crumble easily.
Old 05-03-2011, 02:38 PM
  #53
spinn's Avatar
2004 E500
strange...I don't see the pics.
Old 05-05-2011, 11:40 PM
  #54
revstriker's Avatar
K Car
That is strange. They still show up for me. They are linked in from Photobucket. Is it possible you are blocked from photobucket?
Old 05-06-2011, 12:36 AM
  #55
spinn's Avatar
2004 E500
hmmm...must be blocked at my work; see them on my home laptop.
Old 07-11-2011, 11:24 PM
  #56
tekillah's Avatar
E350
Can you please share your photobucket album so that we can see the pics? The pics in this thread do not come up for me
Old 07-12-2011, 01:06 AM
  #57
bernard farquar's Avatar
2011 E350, 1998 ML320
"this photo has been moved or deleted from photobucket"
Over and over.
Old 07-14-2011, 11:07 AM
  #58
Taylor-Made'90's Avatar
'03 E500
Over and over.
Ditto. Can't see 'em either....
Old 04-03-2012, 08:52 AM
  #59
Flash Gordon's Avatar
2003 E500, 2004 G35X
The photos are deleted for some unexplainable reason as others have stated. These photos would be helpful. Can you post the pictures again, please.
Old 04-22-2012, 08:08 PM
  #60
thumper24's Avatar
2008 E350 Sport
Despite being no pics, I read through the process described and it helped a ton for doing rotors and pads on my '08 E350 Sport. You just gotta man up and get on in there and do it... it's really not that hard once you dig in. May take you longer on the first side, but once you get it down, the next side will take you 30 minutes. Thanks for the guide! My rotors were rusted on so I used the bolt method to get them off after spending half an hour beating on them and didn't budge. Worked like a charm and had it off within a minute.
Old 06-13-2012, 02:19 PM
  #61
lsbrodsky's Avatar
2016 Jaguar FT-R
2009 E350 update
This thread, as well as others on this forum and even the shop CD manual(2008) refer to pins that have to be driven out to remove the front pads. MB seems to have changed this design in 2009. I just replaced my pads and hardware and the front calipers are removed after unscrewing two bolts with a socket wrench. Of course this is a different size and arrangement than the rears, which use an allen wrench.
Larry
Old 08-28-2012, 11:44 AM
  #62
mrbdm99's Avatar
E320 Estate
I'd like to see some newly linked photos as well. This is just what I've been looking for all morning!
Old 08-28-2012, 10:11 PM
  #63
ozusa's Avatar
2004 E320 4matic Sedan
Try this thread as well...
https://mbworld.org/forums/e-class-w...brake-job.html
Old 08-29-2012, 03:48 PM
  #64
VIPCHOI's Avatar
2012 C250 Coupe 040 black
pictures not working
Quick Reply: DIY Front Brake Job 2006 E350
