E-Class (W211) 2003-2009
ESP Malfunction
Old Aug 11, 2010 | 05:38 PM
tcurrie72's Avatar
E 500
ESP Malfunction
After being out of town for a week, I return home to have my 2004 E500 show me the ESP Malfunction. In addition, the blinkers do not work (but the flashing hazards do) nor the cruise control or any of the steering wheel buttons. Are there any remedies I can try before I go to the dealership and get my head ripped-off?
Thank You.
Old Aug 11, 2010 | 06:06 PM
TaxEsq's Avatar
2013 BMW 528Xi; 2010 C300 SportW4 - sold; 1964 230SL
find a good independent shop...
Old Aug 12, 2010 | 10:29 AM
Koolwipski's Avatar
2006 E500 AMG PKG/2010 Camaro SS/RS - 2007 F-150 - 2007 Suburban
My ESP malfunction came up, the cruise control stopped working and my adaptive headlights are inoperable.
My research indicates that the steering angle sensor is bad. All these items will go out when the steering angle sensor fails.
The only other thing mentioned was low voltage on the battery. Apparently, low battery voltage will cause the steering angle sensor to not calibrate or reset casusing it to fail.
Old Aug 12, 2010 | 12:35 PM
gnma's Avatar
'12 Mustang 5.0, '89 Supra Turbo, C55,
Do a search here. I've read something about turning the wheels from lock-lock to reset the esp but I don't know the details. Good luck hope this helps!
Old Aug 13, 2010 | 10:47 AM
lkchris's Avatar
'10 CL550, '12 GL550
Has the battery gone dead recently?
Old Aug 13, 2010 | 05:54 PM
MBtech1098's Avatar
10 speed bicycle
If the battery goes dead, or the voltage drops below around 8-9 volts, the steering angle sensor looses normalization. It does not indicate the sensor is faulty, just that it needs to be re-normalized by turning the wheel lock to lock as mentioned earlier.
However tcurrie72, I don't believe this is your issue. It sounds more as if you have a fault with your SCM (steering column control module) or the wiring to it. also make sure the fuse for the SCM is not blown, which is located at the interior fuse block(driver side dash)
Old Dec 16, 2010 | 02:48 AM
E350AMG808's Avatar
2006 Black E350 SportAmgPackage
So what does the steering angle sensor do anyways?
Whats the price on replacing that at the dealer?
Can't figure out by searching on this forum what the freak is turning the wheel lock to lock? I think Benzworld.org have less content but more reliable. Dunno if people actually know their stuff before posting.
Old Dec 16, 2010 | 08:22 AM
TaxEsq's Avatar
Not to be a d%ck but have you bothered to google "steering angle sensor"? I did and now know what a steering angle sensor does. I recommend you do the same. The forums aren't the be all and all, there is other information out there.
Old Dec 16, 2010 | 04:10 PM
MasterMoparSB's Avatar
A few toys & 07' E350 4matic w/AMG sport packg.
And no one should be driving a Mercedes-Benz if they don't know what "turning the wheel lock-to-lock" means....lol
Old Dec 16, 2010 | 04:16 PM
digitalfuzion's Avatar
E500
I had the same issue a few months ago with the same symptoms that you are experiencing, and the dealer replaced the sensor free of charge.
Old Apr 18, 2013 | 05:16 PM
GregMB's Avatar
Hmmmmm........
registered on MBWorld today, and you already have 19 IDENTICAL posts all linking to this same video that you "found" on the internet?
Looks more like a blatant attempt to drive traffic to your monetized YouTube video.
-G
