E-Class (W211) 2003-2009
Hit a bump in the road recharging A/C
Old Sep 10, 2010 | 07:43 PM
Nickthegreek's Avatar
2009 S550 AMG sport pckg. 2014 Ford F-150 Lariat Supercrewcab
Hi, my drivers side was blowing warm air and my passenger side was blowing cold air which everyone points to low refrigerant so i was going to recharge mine. Talked to the dealer and they said the accumulator is the most common problem. If it was really grimy at the joint then that was most likely the problem. I bought an A/C manifold gauge set along with a vaccuum pump from harborfreight tools and evacuated the system. It held a vacuum for a half hour so it is a minor leak so i was going to go ahead and recharge it. It sucked in a can and a half but from there on it wouldn't suck in anything else and inside the "A/C" off button was illuminated, so there isnt enough refrigerant to engage the clutch. So i am stuck and need to find out how to engage the clutch if possible without using the STAR system. Any advice would be helpful
Old Sep 11, 2010 | 09:31 PM
Did alittle more research and the compressor is clutchless? That is more confusing. Is it still running while the ac off button is illuminated? Any technicians out there?
Old Oct 1, 2010 | 05:06 PM
champa's Avatar
e500 4matic; c240
why not fix the leak? you are going to blow the compressor if you don't. When you sucked everything out and let it sit and suck air, all you did was get moisture inside the system (water in there is no good). You should probably replace the filter now (dryer).... good luck..
Old Oct 1, 2010 | 08:16 PM
apl175's Avatar
The compressor has a variable swash that is modulated by a signal from the front SAM (don't remember which one though). The front SAM is connected via CANbus to the climate control panel. The swash is variable from 2% - 100%.
Even in compressor off mode, the swash still sweeps about 2% by volume at all times. This is still comparatively more efficient than using a clutch.
I believe SDS has the capability to selectively control the compressor when charging the system, but I don't remember which menus you have to enter
