E-Class (W211) 2003-2009
Memory Card - What type and capacity ?
Old Oct 20, 2010 | 01:11 PM
faz999's Avatar
E350 -2012 W212 4 Matic
I purchase 16GB SDHC card for my 2009 E350 i wasnted to copy all my MP3 and play from memory card.
16GB SDHC class 10 card doe snot work any reason why ?
I have a 2GB regular SD card that works fine.
Question : what card will work and max capacity ?
Old Oct 20, 2010 | 01:26 PM
odessit's Avatar
2009 E350 Sport (gone) 2012 E350 (gone ) 2014 E63s ( gone ) 2016 E63S Diamond white 2019 E63s AMG
From what i remember reading you can only use 2GB sd card as the largest possible.
Old Oct 20, 2010 | 01:54 PM
faz999's Avatar
Thanks for the reply wow that sucks. Don't get it why they would limit the card reader size.
Does it really matter if you can read 8gb or 16 gb unless there some rule from other electronic manufacturer's limiting Mercedes. I simple software upgrade will fix it but i guess that is to easy..
Old Oct 20, 2010 | 03:59 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I've found that it isn't the card size but the format SD vs SDHC. SDHC cards don't work for some weird reason. I use a 2GB SD Card, and it works fine, just copy as many songs on it, then get another one for the rest of your songs.
Old Oct 20, 2010 | 04:06 PM
clkwork's Avatar
CLK63 Black Series
They didn't choose to limit it, it was a limitation of the technology at the time. The SD card standard could not address anything larger than 4GB of memory space so they came up with SDHC to extend that to 32GB (or as much as 2TB if you don't strictly follow the SDHC guidelines). The problem is devices designed before the SDHC standard do not know how to address the new SDHC cards. Newer devices are backwards compatible (SDHC device can read a SD card) but not the other way around.
Note, I think while 4GB was technically possible in the standard I don't think anyone ever made 4GB regular SD cards. All of those are SDHC as far as I know, so you're stuck with 2GB.
edit: actually Transcend did make a standard SD 4GB card that wasn't SDHC, part # TS4GSDC. There might be others if you google around.
Old Oct 20, 2010 | 04:10 PM
clkwork's Avatar
CLK63 Black Series
Here's one that looks super sketchy but hey it's just 20 bucks
http://cgi.ebay.com/ws/eBayISAPI.dll...m=320389009211
Old Oct 20, 2010 | 08:59 PM
faz999's Avatar
Thanks all for the reply
I just purchased 2Gb trandsend from amazon 5.69 shipped i guess i can buy 2 or even 3 of them.
Old Aug 10, 2016 | 09:08 AM
Myke's Avatar
2010 e 350
16G
Please where can I purchase 2010 e350 memory card in Nigeria. ?........Thanks
Old Apr 29, 2024 | 05:34 AM
Mattcedesbenz's Avatar
W212 E250
128gb
Spoiler
Old Nov 30, 2024 | 04:42 PM
E2233's Avatar
2000 E320 2009 E550
MEMORY CARD
I have an 2009 E550. Memory Available 4GB. I couldn't find an option to access the 4GB. Can I used the allocated space to add additional CDs?
