E-Class (W211) 2003-2009
HID Kit - error code only when
Old Nov 3, 2010 | 10:27 PM
seahonu's Avatar
2015 GLK 250 BT
Recently installed the DDM Tuning HID Kit, without the error eliminators. And interesting that I've discovered that all works perfectly fine with no error codes - if I'm set to manual mode to turn on headlights and etc.
But when I set the system with lamp circuit headlight = constant (meaning daylight running mode on), the system after 5 mins will trigger an error code.
Humm, so why would the system trigger the error code in daylight mode and not in manual mode?
Thanks,
Old Nov 3, 2010 | 10:59 PM
M-bENZ's Avatar
Corrolla
When did you buy the DDM kit ? I looked at their website earlier but there is a message on their site says something like "back orders" some like that...just wondering how u get it...
Andy
Old Nov 3, 2010 | 11:00 PM
rsmith7's Avatar
Veteran: Navy
2009 E350 Arctic White AMG Sport package W/ P2 option, 2002 C230 kompressor Coupe
I do not believe you can have the daytime running lights activated. I leave the switch in auto and do not activate daytime running. You may want to read more on this i the HID sticky.
Old Nov 3, 2010 | 11:26 PM
seahonu's Avatar
2015 GLK 250 BT
To rsmith7: Yes, but there's actually several headlight modes we have on our W211. 1) total manual mode, 2) auto mode with daylight running mode on, or 3) auto mode with daylight running mode off. Its that mode #2 that only triggers the error code. I believe what's happening that with the daylight running mode on and during bright situations, the system is running at partial watts/amps and in combination with only running 35W, ie. something less than 35W, it'll trigger the error code being less than 35W. In the other mode, the full 35W is drawn.
To M-bENZ: I got this about a month ago. And it sat on my workbench for awhile. So I had ordered this over a month ago or longer.
Old Nov 3, 2010 | 11:28 PM
M-bENZ's Avatar
Corrolla
i see.
Andy
Old Nov 4, 2010 | 04:28 PM
t0ast's Avatar
W203, W211, W212
Usually in daytime running mode, the headlights run at reduced power. Hence, your ballasts aren't getting enough juice to run properly, and its triggering the error code.
Old Nov 5, 2010 | 11:46 AM
seahonu's Avatar
2015 GLK 250 BT
Yes, that's what I thought. Anyone know what is the reduced power in daylight running mode?
