E-Class (W211) 2003-2009
Automatic time change doesn't apply anymore
Old Nov 9, 2010 | 01:59 AM
Mackhack's Avatar
Guys,
I have enabled summer/winter time change to be done automatically but of course since the US officially changed the dates COMAND clock doesn't change times anymore on time and since my cluster clock is setup to sync with my COMAND it doesn't do that of course either.
Is there an update that would fix this problem?
Old Nov 9, 2010 | 07:16 AM
06e320cdi's Avatar
2008 ML320CDI
Mine didnt do it either, and quite frankly I dont remember if it ever did. I know it will adjust for crossing timezones
Old Nov 9, 2010 | 09:38 AM
Mackhack's Avatar
Correct. I did set this one up too and it's working with the navigation system together IMHO!
Old Nov 9, 2010 | 10:11 AM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Since the clock uses the GPS to set the time and adjust for time zones, does it use a fixed DST adjustment, or look to the GPS signal for DST information?
'07 E350
Old Nov 9, 2010 | 10:28 AM
Mackhack's Avatar
'07 E350
That's probably correct as you can display the GPS time but I think that it isn't the US standard (although GPS is operated by the US vs. Magellan is a GPS system developed by the European companies and governments but not in use as of yet as a side note).
Old Nov 9, 2010 | 01:06 PM
N_Jay's Avatar
The European system is called Galileo.
Existing GPS equipment will not use it, as it will require new/different received and decoders.
The question remains, does the MB Command system use a date table to establish DST or does it follow the DST bit/flag in the GPS data stream?
Old Nov 9, 2010 | 02:21 PM
Mackhack's Avatar
Correct, I was on the go when I wrote it. Magellan and Galileo were both important people back then and perhaps today too with their discoveries!
You posted a good question and I hope we can get a satisfying answer here!
Old Nov 9, 2010 | 02:36 PM
weinschela's Avatar
'14 E350 wagon; BMW G12 (2020) G01 (2019)
Time Change
I don't think any of my E's have automatically adjusted for daylight savings. My S, some years ago, did.
Old Nov 9, 2010 | 02:51 PM
Mackhack's Avatar
I think I changed it with my SDS. But I think you can set it also in the navigation service menu.
Old Nov 11, 2010 | 06:52 PM
Mackhack's Avatar
I just double checked and there is a setting in SDS to enable/disable this feature!
Now the question is who would know where the car would get the data from such as the time change? Too bad that I missed the time change recently otherwise I could have enabled it and checked if it works. Then we would have known.
Old Nov 11, 2010 | 07:36 PM
crawdad62's Avatar
2008 E350 4Matic
So did you get it synced to the proper time? I just saw that the clock was off and when I set it correctly and re-enabled the sync the clock moved ahead an hour.
I wasn't sure where it was getting the time info. But the GPS makes sense. It must get the data through the satellite because I don't see anywhere to adjust it in the COMMAND menu.
Old Nov 11, 2010 | 07:46 PM
Mackhack's Avatar
My time was manually set in COMAND and since I enabled COMAND and cluster interface clock to sync my ci clock always syncs to the COMAND time. So I'm not sure at this point. I enabled the summer/winter time change with SDS and will check next year in spring if it does it automatically.
Old Nov 11, 2010 | 07:54 PM
konigstiger's Avatar
'71 Pinto
https://mbworld.org/forums/e-class-w...ing-clock.html
Old Nov 11, 2010 | 08:07 PM
Mackhack's Avatar
I know that but the question is how does the car know when to change since the government changed the dates a few years ago to have a longer summer time of 4 more weeks?
Old Nov 11, 2010 | 08:41 PM
crawdad62's Avatar
2008 E350 4Matic
I found that thread after psting here. I now have the COMMAND unit set correctly and the sync turned back on.
Mackhack from purusing that thread it doesn't look like it knows how to change for DST. It is smart enough to know you've passed into a different zone but leaves the DST changes up to manual setting (at least that's my take).
Old Nov 11, 2010 | 08:53 PM
Mackhack's Avatar
The time sync feature does only sync the dash clock with the comand time. I didn't see a summer/winter time change in the cluster menu or comand. So I think only via SDS it's possible and I still think that doesn't work correctly anymore in the US since the changing dates have been changed. That would really make it worth to bring out an update for the corresponding control unit.
N_Jay's Avatar
Seems to be.
Does Germany have DST? (Could be the reason it is skipped.)
I love that it does time zones. but wish it followed the DST flag from GPS.
Old Nov 11, 2010 | 09:12 PM
Mackhack's Avatar
Yes we have dst too in Germany. Would that be something to address to mbusa???
Old Nov 12, 2010 | 08:59 AM
N_Jay's Avatar
Do the new cars still lack this feature?
Old Nov 12, 2010 | 12:31 PM
lsbrodsky's Avatar
2016 Jaguar FT-R
My 2009 will allow you to change to DST in Command with one button, but it does not have an option for automatic change. The time signal comes from the satellites and syncs the dash clock with the Command clock.
Larry
Old Nov 12, 2010 | 01:21 PM
Mackhack's Avatar
2009 uses NTG2.5 I think. So there might be the difference. We're still using NTG1 COMAND units.
Old Nov 12, 2010 | 01:29 PM
Diesel Benz's Avatar
Larry
But my 221 also gets the UTC time from GPS but it still changes automatically between summer/winter time or DST if you wish. The DST info is not provided by GPS, the car needs to know it. It is either provided with the navigation database or from the RDS radio.
Our 2009 W212 with the standard head unit does change time automatically, the 204 equally.
Old Nov 12, 2010 | 01:32 PM
Mackhack's Avatar
I just enabled summer/winter time change via SDS just for the purpose of checking if it will change next year.
Old Nov 12, 2010 | 09:22 PM
N_Jay's Avatar
DST bit/flag is in the GPS signal. It is up to the receiving device to use it or not.
Old Nov 14, 2010 | 08:42 PM
Heatwave's Avatar
Veteran: Navy
2007 E350; 2018 GLE350
The manual for my '07 E350 states that the clock automatically adjusts for time zones, which I have seen it do, but it does not auto adjust for daylight time. I reset mine using the controls on the COMAND unit.
