E-Class (W211) 2003-2009
How do u check trans fluid level E500?
Old Nov 13, 2010 | 08:48 AM
hayseed's Avatar
04 e55
trying to finf out how to check fluid level on 7 speed e500? dealer put in trans control module under warrenty but something does not feel quite right --
Old Nov 15, 2010 | 07:37 PM
lkchris's Avatar
'10 CL550, '12 GL550
Take it to dealer and have them check it with their computer.
There is no provision for a dipstick.
Look underneath your car. Is the transmission leaking? If it isn't, you don't need to check the fluid. If it is, have it fixed under warranty.
Old Nov 17, 2010 | 10:14 AM
vettdvr's Avatar
03 E500 and Corvette
Conservation of matter it can only be converted from one type to another....
If full when you started with the car, and If it isn't leaking it is still full unless you suspect really hot enough to burn it out.
