E-Class (W211) 2003-2009
2004 E500 Front Suspension Squeak
Old Dec 9, 2010 | 02:05 PM
ThisSideUp's Avatar
e500
I have a 2004 E500 with Airmatic suspension. The front passenger suspenison squeaks. You cant hear it with the windows up but when they are down you can hear it very well. Of course everyone you drive by can haer it as well. I tried spraying lubricant in all the suspsneion points but think it may be coming from the airmatic strut itself. Has anyone experienced this or are there actual lubrication points I may have missed? Any info would be great because this squeaking is driving me crazy!
Old Dec 9, 2010 | 05:37 PM
Barry45RPM's Avatar
2015 ML 350
You may have missed Ball Joints or Engine/Transmission Mounts
Spray lubricant would never solve any front end squeaks Its always parts that need replacing.
Old Dec 9, 2010 | 06:35 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
***** joints. my passenger side does the same. time to replace
Old Dec 10, 2010 | 11:00 AM
ThisSideUp's Avatar
e500
Thanks! I think you are right as when the car is sitting still and I turn the wheel I hear the squeaking. I will start with replacing those and hope it works! Anyone know the part #?
Old Dec 10, 2010 | 11:02 AM
Benz-O-Rama's Avatar
As stated, it's most likely the very common ball joint/thrust arm issue. My passenger side started doing at 50K miles, and now my driver side is doing it at 104K miles.
With the car parked, if you just push down the fender, you'll hear it. Or, you can raise/lower the airmatic, and hear it too. Very common in these cars.
Old Aug 20, 2014 | 09:58 PM
sstan084's Avatar
Mercedes Benz E500
Lower Ball Joint Replacement
What was the cost to have the ball joint repaired?
